head swap on a 93 civic
Re: head swap on a 93 civic
....and an adjustable cam gear, also i think you may need a z1 or y8 timing belt? not sure which one. make sure to remove the screw on the block for the oil to go through for vtec, and you will have to hotwire the plug in for vtec
my car is a civic Si hatch, the d16z6 lost oil pressure really bad so i yamked it out and put a d15 non vtec in it for now and if i can fix the d16 i wont put the head(d16) on the d15. ive plastigaged and found number 1 and 5 main journal to be outta spec by about .3 mm
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
BREADFAN
Apr 15, 2015 08:58 AM
