1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 Civic Vent control issues
Old Oct 23, 2010
HommeDeBois's Avatar
HommeDeBois is an unknown quantity at this point
I've got a 95 Civic Dx, the a/c vent control works all around except for the vent control, the only setting that works is the front vents. The feet and defrost (and the combination settings) just don't work. The buttons light up when you press them, but the air stays the same. The fan speeds work, the inside/outside setting works, the A/C turns on and off, it's just the directions that are having issues.
Any help or ideas?
Thanks!
Old Oct 23, 2010
lazlong's Avatar
Re: 95 Civic Vent control issues
There's a little motor in your A/C unit that switches your vent doors. Either that has gone bad or your A/C control switch is bad or there is a loose connection/broken wire somewhere. Check http://www.honda-tech.com/, they may have a PDF service manual.
Old Oct 23, 2010
Cool, what is that piece called? or what would be the best search term for that kind of thing?
Old Oct 24, 2010
lazlong's Avatar
I would strongly recommend you get a manual even if it's a haynes or chilton to diagnose before you go ripping the car apart. To get to that motor you have to take the entire dash off then take the entire A/C assembly out. It usually take several hours. With 15-30 minutes of diagnoses you can save yourself a lot of blood, sweat, and tears.
mode motor is #5: http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
control switch is: http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
More places to get parts: https://www.civicforums.com/forums/8...ead-first.html
You can sometimes find a manual at half-price books. Usually the parts store has one in your model. Or for factory manuals: http://www.helminc.com/helm/homepage...051&Style=helm
Old Oct 24, 2010
Yeah, I got the Haynes, but it just skims over that area. It shows how to get under there, but it stops there, no help with problem diagnosis or pointing out individual parts. This is a secondary concern right now, I'm doing a head gasket and up renovation of the engine first. I'll def be poking around down there before too long- winter is coming and I'm going to need that defrost!
Old Nov 7, 2010
Got it, it was the fuse.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
cooldan1
Apr 23, 2015 10:49 AM
Microbiology
Nov 9, 2001 10:10 PM
locozoko
Nov 8, 2001 06:33 PM
CivicHX01
Nov 2, 2001 08:49 PM
