1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Engine Stalling, Need some tips
Old Dec 25, 2010
xlylegaman's Avatar
xlYleGaMaN
xlylegaman is an unknown quantity at this point
Unhappy Engine Stalling, Need some tips
Hello guys my very first post so I will get to the point, I have a 1991 Honda Civic Sedan DX. The problem is, whenever I run low on gas, or sometimes just below the halfway mark, whenever I brake hard or brake softly, the cars idle will drop from 750 to about 500, sputter and in some cases just stall, causing me to start the car again. It starts again with no problems. What should I look at first before attempting to fix this?
Old Dec 26, 2010
xXHellxRaiserXx's Avatar
xXHellxRaiserXx is an unknown quantity at this point
Re: Engine Stalling, Need some tips
i would say your not getting enough fuel pressure possible fuel filter or fuel pump problem thats where i would start at least
Old Dec 26, 2010
sleeper101's Avatar
sleeper101 is an unknown quantity at this point
i know this might sound weird but i had the same problem but mine was caused bY a cloged cat. so i switched to high flow and bam problem solved i was ahhhh like ok wow it worked . one of my friends helped me with it but then again i also changed everything to do with fuel lines before friend gave me idea about cat. hope it helps.... what happened was the guts of the cat broke loose and when i breaked the insides moved around and caused a BLOCKAGE.
Old Dec 26, 2010
BlueEM2's Avatar
Whachya lookin at?
^ I agree, check your catalytic converter. Do you have any issues on regular driving? Power loss? Etc?
Old Dec 26, 2010
xlylegaman's Avatar
xlYleGaMaN
My cat is still good and what now. Also this happened after I installed a new header and exhaust (but thats for another thread), this only happens when near empty or below half way mark, when full there is no issue whatsoever, every runs like a beauty. Besides the fuel pump, what else can I check for this? Ill test the fuel pump once this blizzard in New York blows over.
Old Dec 27, 2010
lazlong's Avatar
Sounds like it's either the actual fuel pickup or your fuel tank pressure valve. Bear in mind, it could still be the fuel pump, fuel filter, EVAP, or EGR. And, of course, the first thing to do is change your gas cap (cheap insurance).
docmartin14
Jul 30, 2015 11:26 AM
crowtoo
May 11, 2015 06:50 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
CivicHAR
Jan 4, 2002 09:17 AM
