1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
h23 swap need help
Old Sep 7, 2010
white93coupe's Avatar
white93coupe is an unknown quantity at this point
h23 swap need help
ok guys i got a h23 wanting to drop in to the eg but i know i need mounts and shifter cables and assembly and resistor box so i been hearing some people said ill have to cut down passanger side mount and redrill it or will the mount take care of that ? and is there any where there a good diy on it need imput please and help thanks guys ?
Old Sep 7, 2010
02civicsi02's Avatar
Low and slow!
Re: h23 swap need help
I am pretty sure they make a mount to make it fit instead of cutting and redoing it. They usually have mounts for everything these days to make a motor fit except for the J series motors cause the mounts either put the motor up to high to have to cut through the hood or it is way to low in the bay that it can rub the ground easy and there goes your oil pan and pump. But pretty sure they make mounts that make it work. Go check out Hasport.
Old Sep 8, 2010
ok thats what i thought but now what about axle comb i have to do for it and would any one know a good diy write up on this greatly appreciate the help in
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
rob2905
Sep 8, 2015 01:26 AM
