- a/c problem
- need a pistion ring kit b18c1
- my project 80
- civic overheated now wont turn over
- Ground control coilovers 91-93
- Burned Speed Sensor/ Car Won't Start
- 1994 Civic Overheated and now its hard to start.
- I need ideas, Please.
- Mini me swap....NO fire from distr.
- Anybody?
- radiator ?
- 1991 honda civic hood release cable
- cel crank positon ???
- '94 Civic DX Dies When Pressing Gas?
- 94dx idies then drops and gos back up
- 95 DX project.
- Air Conditioner Transplant for 1980 Civic
- Where to find Silver Trim for 1980 Civic
- Rust by the left and right side corner of bumper screws
- Check engine light and code list
- Rebuild Possible?
- "Clicking" noise from '94 Civic motor. Not quite a knock though.
- Starting issues
- Windshield wiper loose control handle
- Honda civic with v-6??
- 95 ex coupe- a few questions
- plz help TDC 1989 civic ef
- 1980 Honda Civic Carburetor Insulator NEED
- Engine swap ?s
- help me quiet!!!
- paint job
- got my first honda. have a few maintenance questions
- 1989 civic ef v cover
- Vibration at certain RPM..
- Random Stalling STILL???? why?!?!!
- A/C issue
- Getting the idle right?
- Replacing the Power Steering Hose on a 94' hatch
- should i swap? b16a2 vs h22a
- Idle screw
- 90's hatch
- 95 dx/eg coupe
- 91 Civic Electrical Issues
- Trying to decide on a hatch
- Won't Start, need HELP!!!
- Timing belt "slack" on a '93 dx
- B16a EG Header
- 95 EX idle surge
- 95 lx
- please help with ls swap mods
- Raido power wires melted
- clutch replacement
- water from the muffler?
- 93 civic dx coupe, stereo reciever dead?
- 93 Civic DX Lost Power On Highway...
- Piston rings and a ton of smoke...
- Clock
- Tire and fender rubbing >:/
- 95 Honda Civic Coupe 1.5 LSi Front Windscreen Demister not working?
- 95 Civic Coupe 1.5 LSi Bodykit?
- Transmission or Clutch?
- D17 dreams
- Civic wagon just died, cranks, but won't start?
- Help! D16z6 issue
- fuel injector system error code
- Engine Question
- 94 civic b18c1 swap need help with speedometer
- need a 94 civic title
- 4th cylinder misfiring.......HELP!!!!
- Ignition Switch Problem?
- 91 hatch motor swap what i need
- WTF? Transmission?
- Help Please (93 Honda Coupe)
- So What First?????
- ls swap question please help
- Light 98Civic aerodeck
- Idle problem
- F22, K20, Or B18?
- Newbie with a civic that won't start.
- 89 civic lx tries to start, but doesn't
- 1990 honda civic d17zc
- Finally able to play.
- 89 eng help
- Radio install 91 civic help
- need some suspension advice
- 94 civic with b18c1 swap v-tec not engaging
- Starting Problem? '94 Civic DX
- D15b CrankBolt Solved(Read)
- HELP! CIVIC is not getting very HOT!
- Advice??
- bad thermostat?
- Brake light turns off during braking w/lights on
- 92 Civic EX, ABS?
- 94 ex reving up and down by itself.
- New motor with old harness?
- Torn between rebuild or start fresh, 94 civic
- civic brakes
- security system??? HELP ASAP!!!
- help!! 94 ex wont start...!!!
- Replace alternator?
- Is hard shift normal?
- speedometer and clock
- need help
- 92 civic, still burning oil after valve cover gaskets
- 95 Civic EX AC/Cluster lights out
- spoon sports calipers
- fuel pump power
- Need help ASAP on car.
- Frost on the inside of car. . . why?
- Honda LX 95
- 87 Brake troubles
- Need to remove my WHOLE front driver's side door
- 91 civic
- Hello First Post...First 95 Civic Upgrade Ideas
- Can anyone identify this carb!
- 95 civic ex
- My new Civic Barn Find
- spoon color code
- which motor do I have?
- 1995 intake gasket
- Vacuum hose diagram found !!
- New honda owner!!!!
- Coolant leak
- please help. 94 civic dx problem
- drum conversion to disk brakes help
- sloppy shifter....
- Engine starting/running issue
- got pinched for 4'' muffler tip
- b18c1 rebuild forged pistons... turbo or nos?
- 1995 Civic EX with a surging idle.
- 1993 honda civic dx THINKING OF A SWAP?
- CVCC or not??
- lowering springs.. need help!
- 89 civic lx wont start
- lowering springs... need help
- Vac diagram for 1978
- best way to repair rust spots. . .
- b18b problem
- Shifting problem
- Bigger Seats
- 91 hatch PLEAASSSE HELP
- 92 hatch question!!
- 90 civic- sputters and stalls at low rpm
- speedo works and than doesnt work...??
- Speedometer and wiper issues
- new to site and new to honda
- 2001 B18B1 into 1994 Honda Civic Coupe
- b18c1 motor for sale?
- 92 Hatch Interior Questions!!!
- Changed engine now have a strange problem
- Urgent HELP *Please* :: How much gas left in my tank?!?!
- Best Motor For '94 Civic DX???
- What Kind Of Motor Do I Have????
- 95 civic ex-94 gsr swap
- HELP!! with power windows!
- '93 Civic Problems- Idle Search, Vibration, and Whine from Engine.
- Which gauge cluster for 2001 Civic EX w/side air bags?
- is this bad
- Dont know what i have really.
- head gasket?
- 95 Civic EX
- 4dr 94 civic eng. swap
- Door Replacement Help!?!
- 92 civic tranny loud noise
- 90 tranny swap
- 92 civic converter
- Oil Warning Light & noisy engine
- Car trouble help plz
- 1.6L Vtec 94 ex
- Having problems getting civic into gear!
- 89 Civic Hatch
- camber kits
- 94 honda civic ex
- rich starts.
- Dx fog lights
- tranny swap
- Ghost in the Civic
- Door Bushings?
- B20b
- Tail of the dragon 16 + 17 2010
- 1991 Honda Civic won't start
- Problem with '93 HB... Transmission?
- 91 civic CV nut
- stock 91 hatch alternator
- new guy to the 1st gen section
- 1991 DX HB automatic gear indicator light?
- compression test question
- Looking to do a GSR swap for 95 Civic
- vacuum gauge on 95 civic
- exhuast question
- Timing belt failure = poor accelaration?
- 93 civic EX URGENT PROBLEM!!!
- cams for a d16z6
- LBJ-Bolt turns-can't get it back on
- '91 LX Rear Motor Mount Removal
- 95 civic questions
- strange behaviour
- Overheating?
- ??? Door Poppers
- Your opinion best engine swap for 92 civic cx
- Troubleshooting help - 88 Civic dx.
- new pics are uppp!!!
- Racing Seats
- tranny filter
- 90 Hatchback Standard
- d16 exhaust and intake work with a b18
- 92-95 D15b vtec into a 91 civic
- idle issue????
- Issue with my 93 civic
- What head(s) will fit on a '95 Civic DX (D15B7) ?
- 91 hatch with issues
- 7 symptoms, one problem?
- Fuel Pump Connections on 1980 Civic 1500 GL
- 92-95 or 96-00
- '90 civic hatchback coil problem?
- 94 Civic Dead after pulling spark plug wire!
- Steering on honda
- 95 dx idle problem when cold
- engine overheating? smoke from manifold area
- not getting gas...surging
- need some help!!
- Multiple problems
- help with my D13B2 please
- identify wheels?
- 93 Civic Dash Removal
- New to Honda, possible owner of '95 EX coupe
- Fuel pump issue
- Head gasket or stuck/bent valve?
- 93 Civic Si Shift Boot Issue
- 95 civic exhuast question
- 95 d16z6 really bad miss
- check engine light and codes 8 and 16
- VECI label needed for timing
- '90 EX 1.6L strange overheating problem
- Car Overheating Need Help Fast!!!!!!!!!!
- '90 EX 1.6L Hard start and crappy idle...help
- K series into a 95 si coupe ?
- 93 civic with a d16y7
- Audio: Extreme roof rattling in my 91 wagon/shuttle...
- oil on my plugs
- 94 Civic VX...yes..VX..and i need help
- '87 Civic 1500 carburetor problems
- 92 eg budget?
- Yet another gutless Civic
- gauge light wont work!
- Hey guys, brake lights out. Bulbs and fuse both good. Switch disengages... And what..
- Problem with b18b swap!!!! Need inputb
- intake manifold
- fast idle block off plate
- Wire Harness question ?
