1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Rebuild Possible?
Old May 20, 2010
SubStn_EGR's Avatar
SubStn_EGR is an unknown quantity at this point
Rebuild Possible?
Hi All, I'm new here and would hope to become a regular!
First off, I have/had a 93 VX (HB) that was unfortunately totaled by in the last snowstorm in February. The front driver side fender was T-boned in a parking lot. Basically the whole nose as pushed over to the passenger side. My insurance company totaled it. I still have it and want to re-build as a project. I need to either straighten the frame/replace front frame supports. Should I attempt a tear down to get started? Or is this a fatal blow? I thougt straightening the frame with some re-enforcement and new panels would do it. I was going to use this oportunity to rebuild the transmission and engine and check all other components on the car.
If I need to replace the frame supports in front, can I use any 92-95 civic or does it need to be a HB? Anyone know a good place for parts near Philadelphia PA? Any suggestions on the re-build?
thanks!
Old May 20, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Rebuild Possible?
Once the frame is bent it's pretty well a lost cause. Even if you straighten it and fix it, the car will never run the same as it used to and it will aggitate you. You can find another one that hasn't been totaled for pretty cheap, just buy it and build it.
Old May 20, 2010
02civicsi02's Avatar
Low and slow!
The reason why insurance totals something is because it will take more money than it is worth to fix it. So you are better off buying another then building it.
GolNat
Nov 27, 2018 03:32 PM
thatcham
Sep 30, 2015 08:28 AM
Whitexj
Sep 30, 2015 02:04 AM
bashea
Sep 15, 2015 04:59 AM
NaturalSelectio
Sep 6, 2015 06:59 PM
