1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
civic brakes
Old Feb 21, 2010
koisser6284's Avatar
koisser6284 is an unknown quantity at this point
civic brakes
hey , i have problem with my brakes on my 95 civic coupe dx , all the rotors , pads , calipers , drum , shoes and cylinders are new , but the pedal sometime is hard and sometime is soft , is that the booster ??? i realy need your help !!!
Old Mar 27, 2010
Re: civic brakes
anyone ??????
Old Apr 2, 2010
CivicPartsGuy7's Avatar
CivicPartsGuy7 is an unknown quantity at this point
Re: civic brakes
Sounds like a master cyl or you may need to bleed the brakes, what is you part # on your master cyl and booster, i may have one
Old Apr 8, 2010
dakmrg's Avatar
dakmrg is an unknown quantity at this point
Re: civic brakes
were the brakes bleed properly? air in the lines is a common solution to this. when it is softer does the performance of the braking reduce?
Old May 10, 2010
Re: civic brakes
it's ok i found the problem , the caliper pins were seize and the cylinder seal were leaking so bolt caliper were replace
Old Jun 23, 2010
voxleo's Avatar
voxleo is an unknown quantity at this point
Re: civic brakes
Mine was the master cylinder when I had this issue. Wasn't too expensive to fix but I have a good mech.
Xuhme
21
Aug 7, 2023 03:40 PM
Poopies
Apr 20, 2017 11:36 PM
McD
Apr 29, 2015 03:50 PM
bsmiley
Apr 27, 2015 01:27 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
