- Test pipe vs. high flow cat
- Engine question
- Gauges
- What's behind this cover?
- B18A Or H22A Fit In '94 Civic DX??
- '94 Civic DX Takes Oil...HELP!
- 95 d16a6-96 d16y8 swap ! Help !
- 93 LX - slowly growing problem...
- Civic HeadCasket :(
- 90 DX died, won't start. Thanks for advice.
- Engines/Transmission..HELP PLEASE!
- car starts without clutch applied
- B18C into a 95 coupe! HELP!
- 94 Civic Engine Swap?
- new to the forum and honda's
- Hi everyone
- whats a first gen worth?
- Civic Hatchback 1988 rearview mirror replacement
- Intro
- WTB: 89 Honda Civic Gauge Cluster
- 1993 Honda Civic DX HB - Reap Wiper not working
- New to the forum
- 95 civic steering rack
- New To Forum and Hondas - Oil Leak mystery and tune up questions?
- 95 ex coupe distrib probz
- Low Idle on my 92 civic hatch
- Audio swap between 1990 DX and 1995 ???
- 92 Civic 1.5 Timing belt tools and supplies list
- 93 Del Sol S A/C trouble
- hey
- 1989 Civic Hatchback Tow Hooks
- Headlight Question?
- 82 Civic Puttering Out Problems
- AC belt removal 91 Civic 4-door DX
- NEED HELP: replaced VSS and cluster, now TRANSMISSION shifting weird. 95 AUTO LX
- 89 civic fuel system question
- Head Gasket
- Engine help!
- d16z6 hp ?s
- 95 EX Running Rough need help
- 1995 Civic ex Master Cylinder Replacement
- 92 dx mileage
- Gas Mileage Too Good To Be True???
- 92 civic Lx showing its age due to heat
- 93 civic hatch missing bad past 3000 rpm
- Tranny Swap
- 93 honda civic B16 engine problems
- Interferance engine or non interferance?
- need help to programme door unlock remote
- 94 DX Coupe Instrument Cluster/tach?
- 90 sedan auto passenger mirror
- 90 sedan auto door jammed
- 90 sedan auto mounted brake light
- d16y8 swap questions
- 92 civic running rough
- 92 Civic not starting
- Vents and A/C compressors
- Body Kit
- b18c1 swap question
- 1994 Civic Wont start and overheats!
- Newb-ish.
- 90 Civic power cable to amplifier broken
- are honda civic eh vti legitimate vtecs?
- car turns off in drive or reverse but not in parking or neutral!!
- D16z6 upgrade?
- 1994 EX fixer
- Tranny Identification
- 93 civic ex knocking sound
- Hard To Start When Its Hot Out
- 95 EX A/C trouble
- Transmission change
- need some help chosing a motor
- Help
- Does this look right?
- 93 Honda Civic starting issues
- Coupe to Hatch?
- 93 civic cx 4cyl manual hatchback....info pls
- Fuel octane?
- 95 DX modifications
- 91 DX Exhaust
- 1991 civic wagon automatic
- Interior swap?
- 92 ex 4dr AC issue
- Canadian DX engine?
- gen4 civic si paint codes
- Theres no way a D16z6 should be this slow
- Fuel and Temp Gauges stopped working!
- 89 Taillights
- 93 dx shaking while cornering
- advice for a good Carb engine
- 1991 civic vehicle speed sensor code 17 problem
- Need Help From You
- Civic 90 Sedan Mirror
- Quarter glass
- 5th gen Civic:R12 pressure readings for high and low side
- Questions???
- New Civic seems to be pinging
- D15B7 Timing marks question and confusion?
- quick question about my key and my ignition/door locks
- wheels offset help...!!
- 94 EX Z6 civic missing ect....
- 89 civic adjustable proportioning valve
- 89 Civic GSR swap
- Help me with my stupid electical problem!!!!!!!!!!!!!
- A/C problems
- '95 Civic burning a LOT of oil
- bumper repair 2005 special edition
- Transmission Swap questions/help?
- 1995 Civic Glacier 1.3 starting problems.
- Need help with 1992 Civic DX ECM
- '96 Civic Sudan - Sound System Upgrade
- CRX - EG8 (which one is better for modification and swap) ?
- 89 civic suspension upgrades
- Need help with questions about 1995 Civic VX
- 92 civic dx hatch won't start
- AD3 Civic
- Rear brake lockup
- '89 EF motor options
- 1991 Honda Civic advice
- si rims
- honda parts for sale
- 85 crx easy problem to fix
- 93 Civic SI Cooling Problems
- crx 85 carb Help me find the perfect idle !! 99,9 fixed !!
- 93 Civic SI Rear Wiper Motor Needed
- rpms
- won't start
- I have an EJ1 Shell
- new honda owner
- 1987 Civic - fuses?
- I think I found my car...
- 81 civic ball joints
- Wealth of problems all at once!
- Help cooling fan not turning on let's pinpoint !
- Idle oscillates from 200 to 1000rpms?
- NEED axle help!!!
- 95 EX, Bad miss after warming up, 1.6 v-tec
- Can someone measure a d15b1 dipstick for me?
- Head Gasket...or???
- i need help to save my 2nd gen civic
- Clutch Going to the Floor, Not engaging
- B16A Swap, Is it worth it?
- what motor should i get
- Do I have del sol tranny in my LX
- D15b4 (aust)
- 1994 Sunroof pulling unevenly
- 1992 Sedan... Yes... Sedan...
- Hey, Questions for Pros...
- mini me issues
- Idle problems
- need help on 95 hatch!!!
- Need help with my Civic 85
- need help with swap for 91 civic
- Help on lowering 94 civic
- What are possible Causes of code 16? 91 civic
- need help 3.2 TL swap in 92 Hatch
- 94 Civic Coupe - Not starting
- '91 Temp sending unit help!!!!
- 95 parts on 92????
- 94 Civic Si - Wipers ALWAYS ON!!
- 1995 cvt tranny making loud reving sound
- !!!!complete part out thread!!!!
- HELP Crankshaft bolt issues...
- options for d16 what can i do?!
- XS Engineering Subaru WRX vs Top Setup Honda Civic EG6
- Engine swap from 94 civic to 93 dx
- D16z6 engine problems.. NEED HELP! :(
- 93 civic with running lights problem
- 1986 Civic 1500 3bb carb
- Bushings/Common suspension problems?
- Problems with D15b7
- Eagle rods for D15B2?
- 87 Cv Joints
- Anyone tell me what body kit this is?
- What body kit is this?
- 93 Civic Strut Bar
- 89 Civic Alternator help needed!
- 95 civic
- 89 DX hatchback How do you switch to MPFI?
- 94 Civic EX
- 89 Civic Wagon Suspension
- Y8 into 91 SI - engine won't crank
- Dash Removal...PLEASE HELP!
- '90 civic RUNNING LIGHT gremlins
- 1990 civic sidemarker gremlins
- Car Trouble, need advise
- Battery fine but won't start....
- Fuel Testing Banjo Bolt
- New Civic
- Head Gasket Replacement on 92 d15b8?
- 84 wagon needs a carb
- 94 honda civic 1.6 vtec burning oil
- d17a2 into a 94 civic dx (d15b7)!!
- 95 dx manual running rough after 2nd start
- Suspension suggestions for a '95 dx coupe
- New to the import scene
- looking to buy a cold air intake for my 94 EX
- Dx-si motor swap
- Questions about part interchangeability
- Is this swap possible?
- how to remove the A/C from a 94 civic ex
- 91 Si Rear Bumper Cover Removal
- Help! How to convert bumper,sedan to coupe??
- Just replaced my distributor and my car still wont start. Appreciate any advice.
- need help a.s.a.p on my 95 hatch!!
- Honda Pros.. Need Your Help !!!
- 88 civic dx for sale $600
- door window fitment question
- 1988 Civic sedan (ED3) Turbo project
- Transmission Has Problems Shifting From 2nd to 3rd
- 94 civic speedo jumps than stops working....
- ef hatch build!!!
- 94 Civic Ex what to do next
- Please help.....1995 Civic Question
- 92 LX Tranny Problem
- New to this fourm and i have a new car
- 94 civic ex ... is it vtec?
- 1991 civic SI rough idle poor mileage
- B18b Swap from 95 Teg into 95 civic DX
- part spec help
- Head Gasket Replacement 1995 civic lx
- 95 Civic EX Owner Newb starting problem and Advice
- d16z6 problem
- 1994 Honda Civic 1.6L (D16Z6) died while driving...
- 92 civic lx tranny problems.PLEASE HELP!!!
- Installing Fogs
- Idle mifire trouble help!
- What would you pay for this car???
- about to do a tuneup
- ignition timing
- Cold Weather and my car
- d15b7 having trouble starting..help
- removing the fuel feeder on filter..
- Clutch/tranny squeal
- 94 Civic EX (D16Z6, automatic trans) mpg
- 1992 Civic DX AUTOMATIC shifts but will not go anywhere
- Backlight on climate control/Gauge cluster in 94 civic
- D16Z6 VTEC engine?
- Selling vintage ENKEI mesh alloy wheels
- fans not turning on help on crx 85 mt
- Dead Alt
- Civic seat foam any aval?
- Drivers side door wont lock
- Help With Seats
- 1991 civic dx upgrades
- Replacing thermostat for fan bypass crx dx
- 85 crx dx clutch problem with clutch not releasing
- 82' engine swap
- Hood wont shut completely!!!Need advice!!
- Selling Exhaust
