1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Test pipe vs. high flow cat
Old Oct 9, 2009
Lionsmane38's Avatar
Lionsmane38 is an unknown quantity at this point
Okay I drive a 99 si. I plan to eventually boost it, but the funds are limited at the moment. I have a 3" cat back from apex on it now. From bottoming out a couple times I think I have loostened the heat shield on my catalytic converter because it rattles a bit around 3,500 rpm.
So this brings me to the quesitons. Since I am going to boost it, I have heard that any cat will limit me a lot as opposed to a test pipe. The exhaust is a deep tone at the moment, because of the 3" piping, resonator, and muffler on it. Performance wise, what will I see a difference in between the test pipe and the high flow? What will putting either one on do to the sound?
Old Oct 9, 2009
Re: Test pipe vs. high flow cat
bump, anyone out there have any suggestions or answers?
Old Oct 9, 2009
ssclayton10's Avatar
ssclayton10 is an unknown quantity at this point
do you have any aftermarket headers installed?
Old Oct 10, 2009
No, I don't just the stock manifold. I don't think I am going to waste the money on an N/A header since I plan on putting a turbo on it. So it'd be a waste. so stock mani -> cat -> after market 3" catback with resonator and muffler is what I have.
Old Oct 11, 2009
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
First things first. what are the emmission standers in the stat in witch you live? Are they required? If so that makes your mind up there you will have to run one. If not then I wouldnt run one with a turbo car. It makes a big differance in power on them. If you were just running a N/A motor it wouldnt matter except for the sound. Would make it raspie and alil louder. It is proven on the dyno tha on any newer car with obd2 that there is only a 2hp gain by removing the cat.
As for the sound factor on your turbo car it will be a lil quiter and deeper with or without the cat. All a test pipe is is a resinator unless its a home built one. then its just a pipe.
Jay
Fabricated Performance
Old Oct 13, 2009
Jay
Yeah I won 't be able to turbo it for a while but I plan to. I live in Illinois and we don't have emissions laws. I think that I might put the test pipe on, but I want to avoid that raspy soundl. I have a big resonator and a full muffler on my aftermarket exhaust so hopefully that helps a bit.
dbagaus
Jun 10, 2015 09:29 AM
cukaracha
Jun 8, 2015 05:41 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
MyCivic
Bolt-on Engine Performance
Dec 9, 2001 11:46 PM
1028CiViC
Nov 18, 2001 03:08 PM
