1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
about to do a tuneup
Old Feb 11, 2009
sik92civic's Avatar
sik92civic is an unknown quantity at this point
on my 92 civic LX, 5-speed.....its got 128K and i just changed the timing belt, water pump, and timing belt tensioner last week.....i'm ready to do a tuneup and get that great gas mileage and performance.....what are all the parts i should change in the tuneup so i could get the most MPG...and where could i get them??
Old Feb 13, 2009
TheMigsD15's Avatar
TheMigsD15 is an unknown quantity at this point
Wink Re: about to do a tuneup
Replace the fuel filter.
Change the spark plugs. Also look at the spark plug wires new set of high-quality wires is worth the cost. They may be permanently attached to the distributor cap, so it will have to be changed as well.
Replace the distributor cap and rotor
Adjust the valves. Be sure to replace the valve-cover gasket as well, especially if you see oil on top of your engine.
Check the belts. Replace if worn.
Check the fluids under the hood and replenish as necessary.
Change the oil and oil filter.
Replace the air filter.
Adjust the clutch.
Service the battery, adding distilled water (if required), cleaning terminals and cable ends.
Replace the PCV (positive crankcase ventilation) valve. It can make your car run rough or stall if it gets clogged, and it's cheap and easy to replace..... good luck man
CivicVoz
Apr 16, 2015 08:07 PM
Stratiotes
May 8, 2009 11:23 AM
IronFist
37
Apr 13, 2006 11:49 AM
DannyK35
Chicago
Mar 19, 2006 04:05 PM
QBoi
Jan 6, 2005 11:35 PM
