1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
b18c1 swap question
Old Aug 7, 2009
turbopseidon's Avatar
turbopseidon is an unknown quantity at this point
b18c1 swap question
just did the b18c1 swap in a 92 dx and started it and it runs super rich barely keeps running and blows black smoke out the back. i was doing some tracing and noticed 2 map sensor sylinoids one on the stock dx firewall and one on the gsr throtlebody now i know i have one to many question is there both pluged in lol.. i unplug the stock dx one and it revs supper high like its going to blow up... and if i unplug the gsr one it stays the same.. also the dx one has a line coming off the goes to go to no where like an extra line ... can anyone one help me out here thanxs..
Old Aug 7, 2009
fracas's Avatar
fracas is an unknown quantity at this point
Re: b18c1 swap question
What year is the swap? What harness and ecu are you using?
Old Aug 7, 2009
its out of a 94 gsr its using the gsr engine harness from the engine and pluged into the stock dx harness . the vtec and knock sensor have also been wired directly to the ecu
Old Aug 8, 2009
update///// i traced the wires on the gsr side and when it gets to the DX main harness there are little plugs in the plug junction so i took out the stock dx map sensor all togeather and pluged that harness into the gsr map sensor and it runs better just reves up and down constantly and i can hear poping coming for the exhaust But its not running as rich as it was, still looking for more ideas ..
Old Aug 9, 2009
more updates... i took out the one map from the dx and pluged the harness into the gsr map and found a vacume line off under the intake, i hooked it all up checked the timing pulled the spark plugs and they were fouled. cleaned up the plugs put it all back togeather and it purs like a kitten...only problem is when you start to go over 3000 rpm it still dumps tons of fuel and you can hear the injectors just a clicking away its fairly loud.. any ideas why its still dumping fuel past idle?
dbagaus
SOHC D17Ax non-VTEC - VTEC Engine Swaps
70
Feb 22, 2023 04:26 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
ClutchMasterOG
May 31, 2015 03:25 AM
TaiChi
Dec 17, 2001 09:09 PM
viper775
Dec 9, 2001 10:52 PM
