1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Gas Mileage Too Good To Be True???
Old Aug 22, 2009
5G_Dad's Avatar
5G_Dad is an unknown quantity at this point
I recently acquired an unmolested 1994 Civic DX Coupe (5sp MT) that has been dealer maintained since new. After oil change, checking tire pressures, etc, I began driving (very conservatively, mostly highway) and covered 305 miles with 5.7 gallons of regular gas. That equates to over 53mpg, which seems totally impossible. I was hoping to see something between 35 and 40mpg, but this just seems too good to be true. I recently replaced the VSS and have had the speedo/odo drop to zero temporarily, while in motion a couple of times, but any unrecorded mileage from that would have reduced my mpg. Any ideas on what might be going on? I always fill up at the same station in the same way, so this is not a technique problem. What is the best mpg anyone has seen from this model? I suppose time and additional fill ups will tell, but I'm just wondering what mpg folks have seen from the 5sp 94 DX Coupe in the real world.
Old Aug 22, 2009
Re: Gas Mileage Too Good To Be True???
well the dx generally has the best mpg since its the lightest and doesnt have any major accessories. 53mpg is on the high side, but possible if you were doing around 55 mph mostly highway miles. or it could be the odo is not properly measuring mileage. you should drive a known stretch of road and see what its doing.
Old Aug 22, 2009
5G_Dad's Avatar
Thanks for the reply. I plan to replace the instrument cluster soon anyway (tried the VSS first) so I'll see what happens after that. I guess it's like anything else, if it seems to good to be true...
Old Aug 22, 2009
Alpha 5's Avatar
I would get on the Highway and drive Mile marker to mile marker and make sure the Odometer is accurate. I would also put a GPS in the car and compare your speedo. Lastly, I would fill the car to the brim, then when you fill up again, go to the brim. That way you know there is exactly the same amount of fuel in the car.
Only way to be sure you are accurate.
Old Aug 22, 2009
5G_Dad's Avatar
All good suggestions. I completely agree. So what kind of mpg should I expect to see from easy highway driving...35-40? Anyone know if I change my instrument cluster, can I roll the mileage up to match what I already have on the car? Can the odometer be swapped between instrument clusters to maintain the current mileage?
Old Aug 23, 2009
okmic1's Avatar
okmic1 is an unknown quantity at this point
I had something similar happen to me. I'm fairly certain my '92 Civic LX normally gets around 39-40 mpg. I drive the same route to work and back everyday. I know it's 26 miles each way. I decided to check it the other day. I put just over 51 miles on the odometer and put .8 gallons in the tank. I filled it up until it was nearly overflowing the tank.
Old Aug 24, 2009
JDMEG4's Avatar
JDMEG4 is an unknown quantity at this point
k i dono how to start my own question im just picked up a 92 / 93 civic ware do i find out 4 sure the year of the car ?
Old Aug 24, 2009
vin number
Old Aug 24, 2009
okmic1's Avatar
Do you have a car title? It should be on there.
Old Jan 15, 2010
rwc_civic's Avatar
rwc_civic is an unknown quantity at this point
I have a 94 dx hatch Auto tranny. I filled up my tank, and started driving. I got around 220 miles to the tank. If that helps
Old Feb 21, 2010
HondaSoul's Avatar
HondaSoul is an unknown quantity at this point
That sounds awesome. I have a 94 lx and I think the best I ever got was 45mpg. On average I think I get about 38-40, on highway. City even when it's super crappy, I've still gotten about 30-35mpg.
TonoAlpha
Apr 30, 2015 04:21 AM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
Thees1
Apr 14, 2015 08:23 AM
