1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Car Trouble, need advise
Old Mar 27, 2009
St Gabriel's Avatar
St Gabriel is an unknown quantity at this point
I recently threw an Intake, Intake manifold, Headers & exhaust into my 92 D16 hatch to give it a lil more move. ever since i did that, the car has been sputtering(sounds like a go kart) & idling extremely low, to the point where it was shutting off when i wasn't gasing it while it was idling. so i changed the spark plugs & wires, that fixed the stauling out in idle problem, but it still idles so low that i have to ride the gear all the way down before shifting to neutral so it won't shut off. Don't know what to do next. the car stutters so hard it shakes it. Also it's running Rich as hell. the smell of fuel is extremely strong to the point where i'm getting high just driving the car down the block. Any help on what i should do next or what you might think the problem is would be appreciated. thx
Old Mar 28, 2009
Re: Car Trouble, need advise
well its not a good idea to throw parts at a car and expect them to work. you gotta get some sort of tuning done using a dyno and an air/fuel controler like vafc. also you can check the intake system (throttle body, idle air valve, etc) and clean all those out to see if it improves.
Old Apr 11, 2009
JDMCivic95's Avatar
JDMCivic95 is an unknown quantity at this point
yea you deffinately need to get it tunned, agree with the guy above says. you car needs to be tunned, to know it has those kinda parts and not stock. if you changed those things you need a air/fuel controller to control them..clean it all, it should improve it all.
Dorval Andre
Apr 20, 2015 05:34 PM
Thees1
Apr 14, 2015 08:23 AM
deus-ex
Apr 13, 2015 12:29 PM
dxb31847
Bolt-on Engine Performance
Nov 3, 2001 05:20 PM
Strychnine
Aug 15, 2001 07:07 PM
