PDA
View Full Version : 1st - 5th Generation Civic 1973 - 1995
Pages : 1 2 3 4 5 6 7 8 9 [10]
  1. specs/info for the 1983 Civic 1500 S
  2. 1985 1.3L overheating Need help!
  3. 91 Civic EX need advice HELP
  4. choke!
  5. 1986 Wagon - Interchangable parts?
  6. Projectors
  7. need help: 94 coupe revs up 4 no reason!!
  8. 95 Civic having problems PLEASE help
  9. 94 lx sedan climate control
  10. 93 civic swap
  11. Smoother suspension
  12. Questions on air/fuel gauge
  13. 94 LX Sedan Swap Options?
  14. Clutch
  15. Newbie here with a timing or head question
  16. 95 civic si coupe gauge problem
  17. 95% done with my swap. VID
  18. 90 civic timing belt failed tonight
  19. Convert to Manual or Not to Convert?
  20. 1986 Civic Coupe 5 speed - Idle bounces, any ideas?
  21. Engine swap
  22. what is a good exhaust for an 88 dx 4dr
  23. 17 inch rims for sale with tires.
  24. Side Mounth Intercooler
  25. Crank shaft pulley
  26. '91 Civic randomly fails to start - Fuel pump problem?
  27. need badly a multipoint intake manifold for d15, or d16
  28. honda civic 1992 - 1.5 si
  29. Newbie here with '89 DX Hatch questions
  30. JDM Switches For EG 92-95 Civic
  31. wts 17"rims
  32. eg parts 4 sale
  33. 95 Civic Dx center console and door panels
  34. 18 inch Motegi rims
  35. Squeeking noise honda civic 93
  36. Fuel line help
  37. 93 Honda civic fog lights
  38. Honda civic 93 Ex sedan Air condition issue?
  39. Parting out
  40. Busted Engine on 95 Civic LX.... Options?
  41. speedo gear change
  42. O...M...G! Help...this is so annoying. (cd unit)
  43. gas tank straps
  44. CarSponsorships.com??
  45. 89 Civic mirrors
  46. My 95 Honda Civic EX Coupe
  47. My Sushi Roll Help with first mods
  48. 91 Civic EX -- should I buy it?
  49. mini-me question
  50. Help with 92 Civic
  51. Problem starting - 1988
  52. whats the diff in generations?
  53. 1988 Civic Alternator Removal - Help!
  54. Stock 92 Civic Hatch
  55. 2nd Gen Civic Roll Cage $200, distrib... more
  56. civic 88
  57. leather in my 94 coupe
  58. What Engine doesn't fit in a Honda?
  59. newbie needs some help with 92 DX Hatch
  60. 1.5 Multiport Swap
  61. cheap beef up
  62. sway problems with 1991 honda civi LX
  63. Quick question
  64. Wheels
  65. 1991 crx
  66. Question from a Noob
  67. 1991 civic dx push button start
  68. 87 Civic Si HELP distributor timing
  69. Upper/inner steering arm/ball joint replacement
  70. Advice on where to sell a '92 Si?
  71. my "new" car
  72. pwr windows roll down, not up
  73. Is my alternator bad??
  74. doors won't open
  75. Fuse problem!!, lights...Help
  76. 89 civic jumpstart
  77. A little insight please!
  78. Oil Leaking and Idling Problem
  79. 1993 civic open cable reel
  80. swap help wiring
  81. Engine smoking
  82. Engine smoking like hell?
  83. Need Help
  84. 1995 dx coupe..WINDOW Replacement!!
  85. B18c with B18c1 internals will it work?
  86. Parts
  87. exhaust help needed
  88. Clock remains dim and resets to 1:00 every time the car is off...
  89. Bit more poop
  90. 95 Ex Coupe
  91. 87 engine swap. help please!
  92. My Honda Civic 1,6 VTEC 16V Tuning '93
  93. engine swap for a 94 civic dx
  94. 11:5 LS/VTEC issues
  95. 92 Civic Shaky Steering
  96. starter problems 1994 dx
  97. motorswap
  98. F22
  99. What engine could I put in an '89 Civ...
  100. Buying a New Civic!!
  101. need some stock parts
  102. HELP HELP PLEASE 83' Civic Carb...
  103. 86 w/ a B16?
  104. vtec
  105. 91 Civic, Ignition and Auto shift lock problem.
  106. Passenger side lateral mirror wanted for 93 LX
  107. Help, 89 civic not starting
  108. VIN Numbers: You should know where your civic was quality built!
  109. spedometer not working 93 DX
  110. 2nd thread
  111. 1st thread
  112. 88 CRX HF part out
  113. Buying a Civic
  114. Civic D Engine Specs
  115. FS/FT:92 DX hatch w/jdm H22-UTAH
  116. Failed the smog test!
  117. Bodykits
