1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Help, 89 civic not starting
Old Jan 19, 2007
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
so my coworker has an 89 civicLX witht he d15 engine. he has 278,000+ miles on it. for some reason its not starting. we have replaced the spark plugs, the distributer. another co worker said that there is spark out of the coil and at the plugs. any ideas on what might be wrong? thanks in advance.
Old Jan 21, 2007
JoeyOKC's Avatar
http://ackakaka.ytmnd.com
JoeyOKC is on a distinguished road
lack of fuel possibly. try taking the outlet line off of the fuel filter(to the engine) and cycling the key to on without cranking. you should see a signifigant amount of fuel come out.
does the engine sound like it's cranking normal?
Old Jan 21, 2007
well, we had fuel we could smell and see it on the spark plugs, we also tested the injector and it was good, we saw plenty of fuel. and we also used a fuel injector tester. i pulled the timing belt cover off and the timing bet was cracked in worn, changed that and it started right up. so thank you for your help.
Old Mar 3, 2007
SI16's Avatar
SI16 is an unknown quantity at this point
I had this problem once and even though there was still spark from the coil; the coil wasnt suffecient enough. Once I replaced the coil it ran fine. Are you able to purchase a coil and try it and if it don't work bring it back?
Old Apr 30, 2007
elusive_da's Avatar
elusive_da is an unknown quantity at this point
Re: Help, 89 civic not starting
check the main felay.... underdash by ur left ankel.... its a small grey box held up with a 12mm bolt.... it has 1 plug with i think 9 wires going to it.... does the check engine light stay on after about 5 sec.? or take ur dizzy off and take it to an auto parts store the should check it for free
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
