1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Failed the smog test!
Old Feb 26, 2006
imported_pete's Avatar
imported_pete is an unknown quantity at this point
My sisters 88 Civic recently failed its smog/emmisions test.
The engine is in great condition but apparently it needs a new cat and egr valve.
Where can i get these and what will be the cost?
Old Feb 27, 2006
uti-student's Avatar
uti-student is an unknown quantity at this point
do some research at local dealers and get a reasonable prices ummm where ya from?
Old Feb 27, 2006
oh is there any aftermarket parts on vehicle due to driveability??
Old Feb 27, 2006
GoneIn60's Avatar
GoneIn60 is an unknown quantity at this point
i had to buy a cat and it cost me like 80 bucks from an internet site, just search around and see what you find thats pretty much what i did.
Old Feb 27, 2006
CG99's Avatar
CG99 is an unknown quantity at this point
Dont get a stock Honda cat.. they cost an arm and leg.
better off getting an aftermarket one, or going custom. this will still turn out cheaper.
Im not sure about the EGR valve though, sorry.
Old Feb 28, 2006
option2's Avatar
option2 is an unknown quantity at this point
If i were you i would probably just buy another stock cat off ebay ( http://cgi.ebay.com/ebaymotors/Honda...41863324QQrdZ1 ) and put in inline, right after the stock existing cat, youll lose some power, but youll DEFINATLY pass smog. After you pass you can always take it off. By the way, how did they come up with the egr valve failure? Did they determin that through the sniffer test (exhaust)? If they did you could probably get by with that extra cat but if they found it through a DTC then you definatly need a used one. For a cheap egr id hit up the local junkyard.
Old Feb 28, 2006
imported_Tricky's Avatar
imported_Tricky is an unknown quantity at this point
Yep as long as you pass, thats the main thing.
I'd take option2's suggestion there, just get whatever you can, install it to pass the test, then remove it if you really want (but replace it with something else asap).
Old May 3, 2006
thanks everyone, we ended up getting a second hand part and passed the test second time round
CBRBlaize
Jun 17, 2016 06:11 PM
jzhartman
22
Jul 23, 2015 10:42 PM
cizsak
Jul 21, 2015 03:39 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
CivicsClass101
Jul 9, 2015 11:14 AM
