1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
cheap beef up
Old May 2, 2007
oopsracing19's Avatar
oopsracing19 is an unknown quantity at this point
cheap beef up
i have a 1991 civic dx 1.5L i am looking for a way to beef up the engine but fairly cheap. the best i have got in a 1/4 mile is 18.89 with a cold air intake for the only upgrade. i want to be able to atleast hit low 18's if not high 17's
Old May 3, 2007
elusive_da's Avatar
elusive_da is an unknown quantity at this point
Re: cheap beef up
get a full exhaust, hi flow cat (or take it off and pound it out if u dont have emissions) change to a multi point fuel injection, or even a vtec mini me, port and polish the head and intake manifold, theres tons of things u can do to make it faster, u want 17's? and when u get to 17's ull want 16's then 15's then 14's and so on.... trust me i started there too....
Old Jun 4, 2007
Buds302's Avatar
Buds302 will become famous soon enough
Re: cheap beef up
do a MPFI swap and a Minime swap.....all this can be done by you for under 200 bux....seriously! i did it.
you will run 14s all day
Old Jun 4, 2007
Re: cheap beef up
so basicly take the intake from my 91 crx hf 1.5 and put it on there? whats a minime swap?
Old Jun 4, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
Re: cheap beef up
minime is basically where you swap the head
Old Jun 5, 2007
Re: cheap beef up
what head should i swap it with? i dont think the bottom end would hold a dohc
Old Jun 5, 2007
Re: cheap beef up
i THINK an ex head w/ vtec is what works
Old Jun 5, 2007
Re: cheap beef up
i thought the ex had a 1.6 would the head still fit my 1.5
Old Jun 5, 2007
Re: cheap beef up
according to some resaearch you have a d15b2 which has approx. 90 hp at6000rpm even a vtec system wouldnt do much a built b series swap would probably be the best bet in your situation. i myself have a 93 civic ex which is a d16z6. so i could either build mine as it is or drop a b series. hasport.com makes b series mounts for ur ride btw
Old Jun 7, 2007
AvianMan's Avatar
AvianMan is an unknown quantity at this point
Re: cheap beef up
He's right. "14's all day long" seems to be a bit of a stretch without a host of other mods - I've been there.
The problem is "expensive" is a relative term - what kind of budget are we talking about here? What kind of skill level? Swapping heads can be a nightmare if all you are used to is changing oil....
My d15 to B16 swap cost me around $1500 back in 2000, and should be considerably less now. Realistically, you need to free up your entrance (which you did with the Intake) and the exit first before you are going to get much out of the old 1.5. A full exhaust is well under $500 for a good one, including the header (no cat), and can be done by the weekend warrior, so Id start there.
Old Jun 8, 2007
Axl Jack's Avatar
Axl Jack is an unknown quantity at this point
Re: cheap beef up
Yes, the EX has a 1.6L. I have a 91.
Old Jun 10, 2007
Re: cheap beef up
also lookin at ur quarter mile time, how are you launching? better launches might bring it down
Old Jun 11, 2007
Re: cheap beef up
launch at 3000 rpm and getting .013-.030 reaction times
Old May 4, 2009
ECivic19's Avatar
ECivic19 is an unknown quantity at this point
Re: cheap beef up
what about a mini me on a VX??
Old May 14, 2009
d350l4710n's Avatar
d350l4710n is an unknown quantity at this point
Re: cheap beef up
One cheep and effective upgrade to improve your 1/4 mile time is a lightweight flywheel. Try and find an 8 lb. flywheel (stage 1 clutch & 8 lb flywheel kits run about 200 on ebay). This will allow your rpms to drop faster when shifting, letting you get into gear faster. You should also get a short shifter while your at it since you can get one for 15 bucks on ebay. Note: Flywheel installation requires dismantling the transmission and professional installation is recommended.
As far as power, upgrading your exhaust will give you the most bang for your buck. This, however, probably won't help your 1/4 mile time as much as a lightweight flywheel.
Top 3 things to upgrade for quick & fairly cheap performance upgrade:
Intake
- $50
Lightweight Flywheel
- $100-200
Exhaust (at least cat back ... get headers & high flow cat to get a real boost)
- $150 for cat back, $100 for headers, $100 for high flow cat (possibly less)
(Note: Prices given are the cheapest prices I have found through research for my own civic. Best prices most often found on ebay.)
For a more beefy upgrade to your car, you should look into swapping your head w/ a d16z6 head ... Otherwise just drop a b16a2 engine into it.
Be patient w/ your upgrades though, do your research & find what is right. BTW, upgrades add up ... you start w/ 1 or 2 and before you know it, you have made many more mods than you you originally planned.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Dawit Melese
Oct 4, 2015 08:02 PM
pilebuck13
Sep 21, 2015 10:45 PM
AffliictiioN
Sep 16, 2015 02:21 PM
