- 1987 crx b18 swap information help please
- 1990 civic Engine Temperature?
- What tuning software for chipped p28
- AC Blower Upgrade
- 95 honda civic si turns off really hard to start up
- is this possible?
- Honda civic racing set up
- Should I buy this?
- honda civic dx hatchback seats
- looking for some parts plz help me
- Thermostat changed and now car will not start...
- help i have idle problem 94 b20
- 1993 honda civic 4dr lx over heating need help
- Performance Suggestions for D16z6
- Anyone know this part number?
- '93 Civic Ex won't start
- ideas
- someome
- Would this '93 be a good buy?
- what is a square wave electronic signal.
- How can you Tell if your Engine is A D16z6?
- WTB 1986 Honda Civic Si Hatchback Headlight Retainers
- 1983 Honda Civic Wagon
- Racing Spark plugs
- Rough Idle and stall at stops
- EJ1 problem..
- Need Help
- 94 civic lx
- need help please!!
- Fix up my car?
- Injector Clips Question
- Need help figuring out what Civic Model this is
- 3rd Gear (D3) Automatic Transmission
- '95 Civic Programmer
- B16 nos
- Simple Yes or No?
- Rough idle. nothing on the net about this.
- 92 hb 1.5 stock no ac
- my black ej1
- Weak Headlight Output
- Turbo Help(1994 Honda Civic)
- Front brakes locked up
- Handling & Road Noise
- Question about transmission
- Flywheel bolts tough! Seals?
- Battery Draining
- Turboing d16b2 engine stock
- Buying First Car
- Xmission Fluid Change (Yes or No)?
- 93 diys?
- Car Tuning
- Need Answer ASAP
- over heats at a stop after driving 30 miles
- Exhaust question
- 87 si questions?
- 1978 civic
- Making power using factory motors?
- What engine do I have?
- My first Honda
- 93 Civic DX Hatchback
- CA smog help
- Ecu
- please help 93 vx throwing code
- Distributor question.
- 93 honda civic dx
- d16a6 won't pass smog. Head swap?
- How to remove 90' civic si outer door handle
- Common problems with 4th gen hatchbacks
- Need help solving a bucking/jerking feeling when accelerating
- ok how to make it faster 93 5 spd stock?
- I Need Answers!
- 1995 Black Civic Si HB, less than 100k mile value?
- Quit running now nothing.
- Need Help with d15z1 Q.....
- quick question
- possible to reach my goal?
- looking for compatible tranny for d16y5
- 98 LX engine swap to V-Tec. Possible?
- Wtb d15b7 engine
- WTB: EG or teggy shell or roller
- Replacing the A/C? 94 4 door with EK d16
- Gear shift gauge?
- loses power when hot
- 1986 Si Turbo for sale
- Looking to build 94 Civic EX w/H22a swap. Any suggestions?
- Just bought '89 civic si. What maintenance?
- Just picked it up. Tell me what you think. 93 civic ex coupe
- Takes tile to idle right
- 95 dx coupe
- Fuel Issues on 90 Civic GSR turbo
- 95 Civic DX - Compatible Clusters
- First Car Questions
- Integra fenders on civic 2/3 door
- 1976 cvcc just in for parts or whole car
- Body Kit at a resonable price ??
- 92 Hatch ?
- suggestions
- best cost affective coilover for 93 civic seda
- 95 ex front end swap need advice
- Oil Pan Gasket
- Wtb d15b7 engine
- my area sucks
- 95 honda civic dx engine swap
- Power steering
- 93 civic type r being built as we speak for sale!!
- New here!
- just wanted to introduce myself
- 89 civic wagon gsr swap
- Need help choosing new halo projectors
- whats a 1986 civic SI worth??
- car will turn off randomly
- My EJ2 transformation ""Bodywork""
- Is this a good deal?
- Questions about Disc Rotor and Disc Pad replacement?
- 91 civic dx mpfi obd1 swap help!!!!!!!
- Need a civic
- 92 honda civic question
- gsr hatch build
- Couple of questions
- 1986 Honda Civic Si Long Cranking before starting
- Need help with buying CRX/Civic
- cant fill up my tank
- motor questions..
- pay-off then build 95 sedan or hatch?
- 95 Civic EX Electrical drain problem...????
- 87 crx vs. si 87 body
- 93 si swapped b16a, strange bog?
- 89 si b16 swap
- d15 timing belt
- H22 to a B16 Tranny
- 92 civic need a automatic transmission
- Turbo Time!
- please help me with radiator hoses
- Victim of vandalism
- 4th gen wagons
- Engine swap, or buy another Civic?
- the great dsm bluetops. need resister box?
- 89 Si and 90 DX, how compatible
- 91 Civic issues First time Honda owner
- New User, New Driver, First car.
- help figuring out civic
- Looking for a civic/crx/integra shel
- Fair price for '86 CRX HF?
- part out or sell 92 Civic LX
- winter- what is your running time to operating temp?
- new to the site....
- thining about picking this up do you think its worth it?
- re-build engine kit
- where to learn more about engines?
- How to get better gas mileage/more power out of D15
- U.S. Marine needs help answers to car questions.
- 5th gear problems
- Bought car. Has problems.
- Do motor mounts have an affect on the transmission?
- door swap questions
- resurrection
- 1990 Civic HB engine question
- Rims and tires
- Too many miles?
- 95' civic !rack and pinion!(NEED)
- First car, Need help!
- 1992 Civic VX Driveablility Help Needed
- D15 to D15 vtech engine swap
- b16a vtec help
- 1994 EJ1 fs/ft semi-built B18c1 on 50 shot nitrous
- Cold Night
- 95 civic vabration at idle
- 91 civic timing belt question
- how can i get my civic to burn out good
- 89 Civic stops running when warmed up
- K20 swap in my 95. Speed sensor help!
- 95 Civic DX Headrest Removal
- 95 gsr swap or a 04 G35 sedan AWD
- 95 jdm civic sedan front bumper
- New to Civics
- CYP error but NOT the CYP!?
- need to find oil pump for h22 for cheap....
- civic vs stock 240?
- **D1.5B (JDM) Help!! Please!**
- Causes for temp gauge variations on 94 civic?
- cluster swap 95 dx
- engine harness swap
- Please Help!!
- Whinning Noise
- 89 Civic Rear Speaker Pods
- mini me swap help
- d16z6 Crank Pulley/ Harmonic Balancer
- ENGINE SWAP 88 civic hatch question
- 83 civic info
- Dropping a vtec into my vanilla 95 dx
- How to Find the Check Engine Light Code on a 1988 Honda Civic
- no start 92 civic 1.5 16 v
- 95 Honda Civic new engine needed
- Civic 93 will not start. Cranks up, but will not start?
- What Horesepower does your Civic have?
- FWD to RWD
- Vtec Solenoid question
- tps 95 civic 1.6
- smashed 93 dx hatchback - please advise
- new to honda
- 1993 civic relieve fuel pressure?
- Valvoline MaxLife DEX/MERC ATF in 93 Civic?
- 90 CRX si tranny in a 91 civic dx
- power steering leak
- help on tire size!!!
- 94 civic
- project car
- 91 civic wagon
- What car should I get next?
- 91 transmission swap, need help
- 91 civic no start
- Ideas please.
- How can I make Vtec kick in harder
- My VTEC will not kick in!
- hood gap
- Clutch is gone!
- Oil level on dipstick a little more than 1/8" over
- looking for mod ideas
- new member, first car, many questions!
- new member
- Creaking noise when turning the steering wheel
- 90 civic hatch auto to manual
- New exhaust O2 question
- 85 civic
- making an 12 second civic
- Loudest possible exhaust on 95 civic ex coupe
- 1993 civic hatch with j32 swap HELP
- Engine swap for 92 Civic CX
- 95 Cvic DX Sedan (SOHC) non-vtec
- please help!!!
- 91 Civic dx
- 86 si rims and tires
- Civic VX parts compatibility?
- Can I use parts from a 99?
- super snake competition
- so i aplogize but i need help plz
- Would this be a blown head gasket?
- engine wiring problem
- 94 Civic Four Door w/ Vtec Engine Recent Purchase
- clutch model year swap
- looking to trade for 94 civic need some advice
- 86 Si, can anyone help?
- 92' Civic - Metal cover sunroof - No glass??
- Best Engine/trans swap for 92 hatch?
- Lip Advice Needed! NAME THIS LIP!
- Help me find my service manual for my Honda Civic please...
- Swapping carby, carburetor on Honda Civic 1993 sedan D15B24, EG, 1.5litre
- Feel kinda dumb for asking this....
- Help I cant see 86 civic si
