1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
My VTEC will not kick in!
Old Nov 15, 2011
93Civicvteckid's Avatar
93Civicvteckid should not be trusted93Civicvteckid should not be trusted
I have a 93 civic with a d16 and the Vtec is not kicking in. The Vtec was popping off extra hard yesterday but now its not working. Do I need a new VTEC?
Old Nov 15, 2011
Re: My VTEC will not kick in!
try removing the vtec solenoid in the back of the engine head and clean it out and also the gasket. sometimes sand clogs it up. be sure to oil up the valve again before reinstalling.
Old Nov 15, 2011
Would it be better to buy a brand new VTEC
Old Nov 15, 2011
Maglites94's Avatar
Maglites94 is an unknown quantity at this point
No i have the same motor its really easy to remove it its to plug in a phillips and three 10mm bolts i cleaned my screen and it back to gether worked great untill it started leaking i would buy the gasket/screen there like $15 on ebay.
Old Nov 15, 2011
you may as well try to clean it first. if it doesnt help, get a new solenoid its around $150 i think.
Old Nov 15, 2011
Do they make performance ones
Old Nov 15, 2011
no. it only changes the cam from one profile to another. the actual performance comes from the different cam profile. vtec solenoid is simply a switch.
Old Nov 16, 2011
Maglites94's Avatar
I would pull it see if the screens dirty if so buy the gasket for it. It comes with the screen. I wouldent cleen it and put it back in though because the chance of it leaking is high and new one is $30 or $15 on ebay.
Dave Brabant
Sep 27, 2015 09:43 PM
beanhead
Sep 24, 2015 12:04 PM
