so i aplogize but i need help plz
ok so i really dont know where to post this so my apologies anyways, i just bought sylvania silverstar ultra headlights. I installed them and they are not as bright as my stocks, my stocks are brighter!!! I have a 1995 honda civic ex coupe stock projector headlights oem i guess you could say. Anyways i really need some help and guidance as to what bulbs to buy i need the brightest, best downroad visibilty and most importantly the best bulbs for peripheral vision that is a big must i would go the hid route only problem is i have the stock reflector housing and i have done my homework and know that they look like total crap with glare and horrible cutoffs. So long story short i want the best halogen bulb to give me the best peripheral best down road visibilty and most brightness cuz every bulb i have tried has just been horrible imo. i dont know if i should just upgrade my housings to ebay projectors or k2motor projectors please someone i need help desperately
Re: so i aplogize but i need help plz
philips XV (the XP is good too) from www.powerbulbs.com are the best halogens right now.
will they give me the best peripheral vision cuz right now i have absolutely none its just like straight out to the front and nothing to the sides and thats why i am considering getting fog lights to help address this issue
the bulbs will brighten the existing beam shape, but the actual pattern and spread is produced by the reflector and cannot be changed by the bulb. have you thought about retrofitting some hid projectors in there? ask around on hidplanet.com im sure 95 civics have been done before.
You could try adjusting the horizontal adjustments on the headlights. They may be set to narrow if your not getting a good peripheral field of view. It's quite easy to do. Just park the car in front of a wall so you can see the beams of light and then access the adjusting points with a Phillips head screw driver. There are two access points one for vertical adjustment and one for horizontal (two on either side of course).
and also 95 coupe i was messing around with them and i was trying to move them up n down and i was getting more horizontal by moving them up n down and also to the whole retrofitting idea there is no way i have time or money to retrofit id rather just buy some ebay projectors and throw them in there in all honestly
Here is a link to Honda Tech it has good instructions on aiming your lights.
http://honda-tech.com/showthread.php?t=2086368
philips xtreme are whats in my 94 civic right now. great bulbs and not a bad price. improved drastically after i put new headlights in, and losing the old foggy ones..
