1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1992 Civic VX Driveablility Help Needed
Old Jan 8, 2012
Troy VX's Avatar
Troy VX is an unknown quantity at this point
Hello All,
I'm have problems with a 1992 Civic VX I bought for my son. A quick history, it had a blown head gasket when I bought it. That's been repaired properly but when I went to get it smogged here in Ca. it passed the 15 mph test but not the 25 mph test. It would hold the 15 mph in 2nd gear but wouldn't hold the 25 mph in 3rd so he tried it in 2nd gear.
The smog tech told me to replace the O2 sensor and do a tune-up on it and to look for vacuum leaks as the oxygen on the test data was high. He said that driving it after the blown gasket probably contaminated the sensor and after doing the work to drive it for a while to allow the ECM to recalibrate to the new hardware.
I replaced the sensor and tuned it up and checked for vacuum leaks. Now it runs ok but when you're driving at steady throttle it starts to lose power unless you depress the pedal then it picks up with a jerk.
I was told that it's the system leaning out to increase the fuel mileage, which was one of the features of the VX to get the high mileage ratings that this car gets.
What I'm looking for is, is there anyone on this forum that has some knowledge of the VX drive train and driveability that can help me do some trouble shooting or point me in a direction to head!!! Thanks for any help!
Take Care
Troy
Old Jan 13, 2012
Troy VX's Avatar
Re: 1992 Civic VX Driveablility Help Needed
Anyone? Come on help me out!!!
Old Jan 13, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Does it idle fine? maybe check the fuel filter..when you say tuned it up what do you mean..I do not have one of these so i can only go off of research and general mech knowledge...
Old Jan 13, 2012
Troy VX's Avatar
Hello Gunner,
It idles perfectly, I have yet to check the fuel filter that's this weekend, as for the tune-up it was new Plugs, Cap, Rotor, Set timing, and a new O2 Sensor. Since my first posting I've been told to disconnect the battery to reset the computer, and while there is no check engine light on, I'm going to try to check for any codes. I'm hoping to get this all done this weekend so I can get it smogged and titled.
Take Care
Troy
Old Jan 14, 2012
lazlong's Avatar
How to retrieve your codes: http://check-engine-light-codes.blog...retrieval.html
Sounds like a sensor problem or like suggested, it's a fuel pressure problem. When you tuned it up did you change the fuel filter? It super easy and right on the firewall.
Old Jan 14, 2012
Troy VX's Avatar
Thanks Lazlong,
No I didn't change the fuel filter but I did today and it still is running odd I'm going to get into it hard tomorrow.
mattdoc
Mar 14, 2017 12:10 PM
usajags84
15
Aug 19, 2015 03:12 AM
Myredjonda
Apr 14, 2015 07:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
