1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Handling & Road Noise
Old May 21, 2012
Californication's Avatar
Californication is an unknown quantity at this point
Any tricks or fix ups to improve handling in the steering wheel at higher speeds? Also, ways to reduce Road & engine noise?
Old May 21, 2012
SpeedDownZone's Avatar
Re: Handling & Road Noise
In what car?
Any one will point to getting new suspensions, there is a ton of threads so look around.
For road noise anything from better tires to sound damping.
Check here for that https://www.civicforums.com/forums/2...hinsulate.html
Old May 22, 2012
For a 1993 Civic Ex 1.6L. And for sure, I will look around.
Old May 23, 2012
D16z6's Avatar
New To honda, Not to the strip.
D16z6 is an unknown quantity at this point
We basically have the same ride. As far as road noise, a lot has to do with the tires your using. I run cheap stock 14" wheels and tire in the winter months and 17" wide aggressive street tires in the summer. And there is a big difference between the two.
Engine noise isnt to bad for me, I kind of like hearing that buzz
There was a big improvement in handling with my 17" wheels and 205/40ZR tires. You can do your research and find what kind of suspension you might like. Aside from that, its what you like. Good luck man!!!
Hqly2001
22
Jul 12, 2015 06:44 PM
fvckbg
Jul 7, 2015 07:08 PM
RyanCoult
May 29, 2015 09:50 PM
CaseysGuy385
Dec 26, 2001 01:35 AM
