1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
91 civic timing belt question
Old Jan 1, 2012
CivicTTurtle's Avatar
whats a sparkplug?
CivicTTurtle is an unknown quantity at this point
I'm doing some routine maintenance (idler puller is shot) on my 91 hatch and noticed that the timing belt seemed to have an unusual amount of slack in it. Before I go any further I was wondering if anyone could tell me how much slack is normal in the timing belt. I will post some pictures. Thanks in advance
Name:	2012-01-01 20.44.03.jpg
ID:	82313   Click image for larger version
Name:	2012-01-01 20.44.58.jpg
Old Jan 2, 2012
Re: 91 civic timing belt question
The Honda site only tells how to tension the timing belt. No mention of deflection checks.
Some slack is normal. Hard to tell if that is unusual or not. The belt can stretch a little over time and miles.
If you don't know how old the timing belt is, then just replace it, check the water pump and the tensioner pulley. Cheap insurance.
Old Jan 2, 2012
whats a sparkplug?
Thanks. I have a new water pump and timing belt on hand but both that are currently on are in good shape. I don't want to take the crank pulley off and risk throwing off the timing to replace a perfectly good water pump and timing belt. Thats why i'd like to know how much slack is normal. It seems that usually the timing belt is pretty snug on most vehicles which is why I think this is odd.
Old Jan 2, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
normally for some belts the deflection is 1/4 of the width of the belt....also, if you can twist the belt all the way around (full 180) or more, its to loose...
Old Jan 2, 2012
BOWZ's Avatar
BOWZ is an unknown quantity at this point
my 1990 doesn't have any slack. belt has 12K on it. just my .02
bowz
Old Jan 2, 2012
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
timing belts don't stretch
Old Jan 2, 2012
Actually, rubber does stretch and since a timing belt is made of rubber, it can stretch. Is it likely? no, but it is possible...
Try the steps again for tightening the belt, just in-case something loosened up, belt is still on so it couldn't hurt.
Old Jan 2, 2012
Yeah, they do.
After 100k on a timing belt, you can see the difference in slack from when it was new.
Also, wear can mimic stretch.
Old Jan 3, 2012
whats a sparkplug?
thanks everyone for the help
Old Jan 3, 2012
04 Honda Civic's Avatar
Juding by what I have seen in the past yours is too loose. If your belt is old then change it. If your belt is new, then your tensioner is on its way out. I wouldnt recommend driving on that for too long.
mattdoc
Mar 14, 2017 12:10 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
