1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
no start 92 civic 1.5 16 v
Old Dec 4, 2011
kpoisant's Avatar
kpoisant is an unknown quantity at this point
got this
1992 honda civic
1.5 liter, 16 valve SOHC
4 door
i have fuel pressure, i have spark (all four), i would like to test injectors if anyone could tell me how i have a noid tool set i got at advance.
new
ngk plugs
fuel filter
new distributer (that one of the cover bolts broke in to so ill be drilling that out but zip tie works till i get it going)
new cover for distributer
new rotor for distributer
new wires for plugs all premium from advance and napa.
i cleaned and sanded down the thermostat ground.
i attempted putting TDC, and installing the distributer at pistion 1, cam gear shows UP at the top, the long skiny triangle that i think marks TDC for crank pully is lined up with the white line next to the 3 other lines.
i might have made a mistake not sure during the install and i will remove and reinstall unless theirs any way i can test that pistion ones on compression stroke TDC and the distributers actually on the cam the right way. i tested for spark tho do have spark, turns over qucik just wont start. relay clicks once on 2. ill check the engine code thing tommorow ill look for a how to.
Old Dec 5, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: no start 92 civic 1.5 16 v
1 Set your multimeter to check for resistance or turn on the ohmmeter.
2 Disconnect the wires to the injector.
3 Place your meter's leads on each of the two injector terminals. Read the meter display.
4 Check your service manual for your car's resistance number. Most fuel injectors have a resistance of between 10 to 18 ohms.
5 Test each injector. If any of the injector readings are higher or lower than they should be, you need to replace them
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
EvilTwin
Nov 8, 2001 12:17 PM
