For Those of You
Old Nov 8, 2001
EvilTwin's Avatar
EvilTwin is an unknown quantity at this point
For those of you who want to lower your Civic here are some rules:
Those who want 17" wheels:
1. Get the widest offset possible(usually +40)
2. If you are going with a wheel with a width of 7.5", don't lower your car more than 1.5" or it will rub. If the width is only 7", then you will be safe with a 2" drop.
Everyone who wants to lower it:
1. If you don't know how to put on coil springs, plan on spending at least $100 for getting them installed.
2. When you get your springs put on, be sure to have the alignment done-another $40.
3. Now for the bad news. You are going to have to spend another $250 for a camber correction kit. If you don't buy one of these kits you will end up spending lots and lots of money on new tires. This will also cost you around $50 to $100 to have installed if you are not mechanically inclined.
Old Nov 8, 2001
antidote11's Avatar
antidote11 is an unknown quantity at this point
One good thing about the Eibach Pro-Kit....there's no need for camber correction. : )
Old Nov 8, 2001
AFlyer's Avatar
AFlyer is an unknown quantity at this point
thanks for the info. it was my understanding that if you're only lowering 1-1.5" then you won't need a camber kit, but if you're lowering more, then you will? for those of you with GC coilovers, how long does it take you to adjust your ride height?
Old Nov 8, 2001
civiclized's Avatar
civiclized is an unknown quantity at this point
no camber kit is needed for drops of 1.5 or so...if u go the 2 inch drop then like eviltwin mentioned the camber kit is needed...some places will tell u that camber kits arent needed for that low of a drop, and that all u have to do is take it somewhere and get it aligned, but thats false. cuz if u hit a bump and its low without the camber kit then it will become unbalanced or something like that, so thats why its needed.
Old Nov 8, 2001
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Well, contrary to popular belief, it's not as easy as the guy in the ad....it takes a little more than just reaching inside the fender well with one hand. Much quicker than my friend's coil-overs though. You can reach the back coilovers if you have rims w/ large holes in them, the front you may have to jack up a bit so that you can fit your hand in between the tire and fender. I lift it up when I take it to get my oil changed so that they can fit it on the ramp. Now that I have the routine down, it usually takes me about 5-8 minutes from start to finish.
