1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
please help me with radiator hoses
Old Feb 9, 2012
vcivic's Avatar
vcivic is an unknown quantity at this point
I need to replace all hoses on my 1994 civic SI with a JDM 1993 B16A engine, (all 10) the part numbers are tricky, i looked up the parts for both the 1994 civic SI and the 1994 Del Sol VTEC, and the first 5 numbers (XXXXX-XXX-XXX) of each part from honda are the same matching numbers for both the civic and delsol, but the next 3 numbers/letters are different, and so are the following 3 numbers/letters.
Are these parts the same on both cars, since the first 5 numbers in the OEM honda part numbers are the same?
The reason im asking is the price for the civic SI part numbers are much cheaper than the parts listed for the delsol VTEC
SOHC vtec D16Z6
19501-P08-000
HOSE, WATER (UPPER)
CAN
$12.93
$9.11
19502-P08-000
HOSE, WATER (LOWER)
CAN
$27.12
$19.66
79721-SR3-000
HOSE A, WATER INLET
CAN
$18.65
$13.52
79722-SR3-000
HOSE A, WATER INLET
CAN
$5.55
$4.02
79725-SR3-000
HOSE, WATER OUTLET
CAN
$13.13
$9.52
19506-P08-000
HOSE, ELECTRONIC AIR CONTROL VALVE INLET
CAN
$2.38
$1.73
19507-P07-A50
HOSE, ELECTRONIC AIR CONTROL VALVE OUTLET
CAN
$8.47
$6.14
19508-P08-000
HOSE, BYPASS OUTLET
CAN
$9.03
$6.55
19527-P08-000
HOSE A, BREATHER HEATER
CAN
$4.63
$3.36
19528-P07-A50
HOSE B, BREATHER HEATER
CAN
$5.45
$3.95
DOHC Vtec B16A
19506-P75-000
JPN
$5.42
$3.93
19507-PR3-000
JPN
$8.03
$5.82
19508-P08-000
HOSE, BYPASS OUTLET
JPN
$9.03
$6.55
19527-P30-J00
JPN
$6.95
$5.04
19528-P30-J00
JPN
$6.95
$5.04
19501-P30-000
HOSE, WATER (UPPER)
JPN
$23.28
$16.41
19502-P30-000
HOSE, WATER (LOWER)
JPN
$31.08
$22.53
79721-SR3-J30
HOSE A, WATER INLET
JPN
$20.58
$14.92
79722-SR3-000
HOSE A, WATER INLET
JPN
$5.55
$4.02
79725-SR3-J30
HOSE, WATER OUTLET
JPN
$13.47
$9.76
Old Feb 9, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
Re: please help me with radiator hoses
google an engine diagram for the motor you have...most of the time it will have part numbers...or call a dealer maybe? tell them what motor you have? or take you hoses in to an auto parts store and see if they can match one up....
Old Feb 9, 2012
vcivic's Avatar
I HAVE A b16a JDM engine swap in a 1994 civic SI.
Old Feb 9, 2012
ok.....
Old Feb 9, 2012
vcivic's Avatar
if the first 5 numbers on a honda part are the same, but the next 6 numbers are different is it the same part made somewhere else?
Extractfromtab
Sep 10, 2020 04:21 PM
thaler4cuse
Sep 7, 2015 08:25 PM
johnsoda
Sep 6, 2015 04:00 AM
baconomics
Aug 26, 2015 07:47 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
