Drove while overheated, engine damaged?
Old Aug 25, 2015
Extractfromtab's Avatar
Extractfromtab is an unknown quantity at this point
Hi,
99 civic sedan
Being from Canada, rust is a huge issue. My lower radiator hose clamp rusted right off. But it was gradual and it's been raining a lot so I didn't realize there was a leak until there was no coolant in the system at all.
I drove with the thermostat above the red for about 2 minutes. There was light smoke above the engine, my fan thermoswitch is burnt out (it's jumpered with a wire now).
I replaced the hose clamp, filled up the coolant, the car starts fine and sounds normal. The check engine light was on, but is now off after battery reset. The temperature gauge sits at slightly below halfway when the engine is heated up. I haven't seen any coolant on my oil dipstick or oil in my coolant reservoir.
I am still concerned about head gasket damage though. Should I be making 300 km trips? Should I replace my thermostat or fan thermoswitch? Should I get a combustion and pressure test done?
Old Aug 25, 2015
mikey1's Avatar
Re: Drove while overheated, engine damaged?
drive it and see how it goes, keep your eye closely on the temp guage,
consider yourself very lucky if you dont have a blown head gasket and/or a warped head
Old Sep 9, 2020
El Magico's Avatar
El Magico is an unknown quantity at this point
Originally Posted by Extractfromtab
Hi,
99 civic sedan
What ended up happening to your civic?
Old Sep 10, 2020
Colin42's Avatar
That post is from 5 years ago
Scout1
51
Jun 13, 2020 03:28 PM
JasonHZS
Feb 11, 2016 05:26 PM
Mv7fd
Oct 12, 2015 05:09 PM
thunderfck23
Oct 15, 2012 04:12 PM
BigBearGirl
Sep 14, 2012 03:10 AM
