Overheating Issue (Mechanics can't even figure out issue)
Hey guys, I bought a 2002 Civic EX in June. It had 110k miles on it.
Had a mechanic look at it before buying, everything ran perfectly.
Went and replaced the timing belt and water pump about 2 weeks into having it just to be cautious because I had the money at the time to do so.
About a month ago the car started over heating out of nowhere, mostly during traffic and non-highway driving. Took it to the shop and they told me it was just the sensors and they replaced them (told me the radiator was fine and working properly). Drove out of the shop and about 50 miles into driving it started to overheat again. This time I was on the highway and it shot up to red and started smoking under the hood. Pulled over, notice the radiator hose had popped loose from running too hot.
I had the car towed back to the shop. They told me they had to replace the radiator because this, that, and the third...but they replaced the radiator, hose, thermostat, flushed the system, cap.
Drove away and about 30 minutes of driving it starts to overheat again.
I take it back to the same shop. They keep it for a couple days, have an electrician look at it. He notices a short in the wire from to the fan, says that is the issue. They say the car is working properly but is burning through coolant. They did several combustion tests on the head gasket and all came back negative.
The car runs but burns through the entire coolant fluid in less than an hour. This weekend I put about 200 miles on it and used about a half a gallon of coolant.
Any suggestions on what the issue could possibly be?
A buddy of mine suggested the intake manifold gasket being replaced...but I would expect a shop Ive been going to for a while that is pretty reputable to think of something simple like that first.
I'm at my wits end because I just bought the damn car to save money on gas and engine problems (Had a Blazer before this)
Re: Overheating Issue (Mechanics can't even figure out issue)
read this...
https://www.civicforums.com/forums/3...reference.html
Find a mechanic that knows something about Honda's.
Every time your car overheats it's increasing the odds that the head gasket is blown. Let it overheat a lot and more damage than just a HG will need to be repaired.
Thanks, none of those seem to be the issue. They have done several tests to see if the combustion gasses are leaking thru the head gasket...all tests have come back negative. The heater blows hot air.
and possibly
The radiator cap should have been the relief valve, not any hose.
I'm inclined to vote for mis-clamped hose or broken nipple, barb worn down or missing
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
intensity
May 12, 2015 10:43 PM
rcolosi
Apr 29, 2015 07:48 PM
