1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Would this be a blown head gasket?
Old Oct 22, 2011
mikeyishaggard's Avatar
mikeyishaggard is an unknown quantity at this point
Im still pretty new to cars so excuse the new guy question.
Anyway, I bought a 90 hatch as a project. The guy said this car smokes because it needs new valve seals. However, wouldnt that smoke be blue/grey? This is a thick white smoke which will get more/less dense as time goes on. It also kinda surges sometimes when idling ( which I hear could be a bad O2 sensor?)
Also on an unrelated note. It only starts sometimes. Theres always power to the car but sometimes Ill try to start it and it wont even click. Its like the battery is completely dead but its not. After a few tries it will start up. What could this be?
Ask anymore questions if you need to! All help is welcome!
Old Oct 22, 2011
MindBomber's Avatar
Live for the Twisties
Re: Would this be a blown head gasket?
White smoke = coolant.
Not starting, check the ground wires.
Old Oct 22, 2011
lazlong's Avatar
Yeah, white smoke means it's burning coolant. If it's burning coolant then it's probably a fairly big headgasket leak. Do a compression test to see if it shows anything.
Old Oct 30, 2011
SpeedDownZone's Avatar
Umm my 89 is doing this but just a little white smoke is changing a head gasket hard or something that could be done in a few hours. And while Iam in there what else should I look for or clean or replace.
Old Oct 30, 2011
JohnHenry's Avatar
R.R. Adict
JohnHenry is an unknown quantity at this point
If I were you, I would do a compression test. If you need to learn- a 20 dollar haynes book at autozone will guide you well!
generally speaking white smoke is created through a coolant leak inside the engine usually the gasket between head and block(head gasket). It can be fooling with some that have condensation(water) built inside the muffler from prior day/time cooling tempatures---will go away after the exhaust has heated up and evaporated all the moisture...
Old Nov 15, 2011
Maglites94's Avatar
Maglites94 is an unknown quantity at this point
Wouldent you see either coolant in your oil or oil in your coolant if its a head gasket though?or am i mistaken?
Old Nov 18, 2011
seymour's Avatar
seymour is an unknown quantity at this point
yea im working on a 91 civic with the 1.5L and i replaced the water pump and the head gasket and now it wont start any ideas
mistermenphis22
Apr 3, 2016 08:06 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
arokz89
Jun 18, 2015 08:25 PM
Jun 2, 2015 11:54 AM
HondaHomer
May 14, 2015 12:24 PM
