1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
89 si b16 swap
Old Feb 14, 2012
89slowcar's Avatar
89slowcar is an unknown quantity at this point
89 si b16 swap
car is a true si with the b16 swap. car died then threw tdc code. so new distributor went in. still no luck. car is still obdo and im wondering if the new dist is right or not. it came with the white round plugs so i assume its obd0 but all the internals swap perfectly with my spare sohc obd1 dist. car gets one spark when you turn on the key. and one spark when you turn key off. im stumped.
Old Feb 15, 2012
89slowcar's Avatar
Re: 89 si b16 swap
i have another new distributor on the way and i can just hope that fixes it. dunno what else to do
Old Feb 18, 2012
89slowcar's Avatar
Re: 89 si b16 swap
new distributor did not fix the problem. still no spark.
Old Feb 18, 2012
BlueEM2's Avatar
Whachya lookin at?
Re: 89 si b16 swap
Check to make sure your timing belt is still intact.
Old Feb 19, 2012
89slowcar's Avatar
Re: 89 si b16 swap
timing belt is perfect and it is in time.
tonight i made sure the obd1 conversion harness was installed correctly and checked all my grounds. then i checked all the wire splices and my buddy soldered them and made a better connection and it started!!!!! now it idles at 2200 but it runs. thank you for the response. 200 views and one response hahaha. so thank u
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
