92 honda civic question
so basically i was just using my car yesterday normally, i accidentally put a cigarette between the wheel in under the cluster. (the part that moves up and down to adjust lower or higher) when i got home i tried to look for it and it was frustrating because it just disappeared. i took off a couple clip off plastics under the dash to look in between the wires and such
idiot me forgot i did pull it out earlier on the trip home. this morning i tried to turn my car on and everything works, radio, lights, foglights, windows etc.. everything,
but when i get to the crank position, it wont crank but my radio turns off (like how it normally does when u turn the vehicle engine on)
i can hear my fuel relay run so i doubt thats the problem. i was literally just using it last night. kinda weird it wont start now.
my question here is that, under the cluster, around the wheel, is there something that can prevent the engine from cranking?
maybe i loosened up a wire or such? i was thinking it was my starter* but how can this be? when i was just using it and everything was normally fine
please help. thanks in advance!
Re: 92 honda civic question
Hope the car doesn't develop a nicotine habit. It's an expensive habit.
Pull the floormat out from under the clutch pedal.
Shove the clutch pedal all the way to the floor.
Crank it.
Could need some regular diagnosis to see why it won't crank.
Crank it.
thanks for the quick reply,
xD o man, thats like 5$ everytime i put a new part in for my car lol
but either way, if i had the clutch in or not, me and my friends who helped me swapped the engine bypassed the clutch to whether its pushed in or not, i can still crank it and start the car. it was ready for a remote starter... but i didnt go along with it because i seen a couple videos where wrong installation of it can cause your car to blow fuses and etc...
its acutally raining right now in vegas and i dont own a garage because of the harsh conditions of the world right now. living in the apartment but im going to go outside and slam a couple things towards the starter, and do the headlight tests
please anymore advice or recommendations would be great. thanks in advance forum helpers!
You gotta be observant.
The car doesn't crank, but what DOES it do? (lights, noises, etc.)
Does the starter go KLUNK? Tap on the starter with a small hammer while someone tries to crank it.
Make sure the battery cables are clean and tight.
No noises at all? Make sure your pedal switch wiring bypass is still intact. Make sure the ignition switch itself is good.
I could figure out the problem with not much more than a test light and a wiring diagram.
A starter is easy to figure out if you know how it all works.
what i came here to the forums to ask is around the wheel area and under the cluster, is there wires there that are easy and usually loosen up when tampered with and makes 5th gen hondas stop cranking?
jessicakaybby
Apr 20, 2015 12:11 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
92, civic, civicforum, civicforums, crank, diagram, honda, jayjaypops, location, nss, remote, start, starter, wire, wiring
