1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Rough Idle and stall at stops
Old Jun 10, 2012
Freek21's Avatar
Freek21 is an unknown quantity at this point
Hey guys,
My '93 civic ex i having some issues with rough idling and stalling whenever I come to a stop. It only happens once the car is hot. It will idle really low and barely stay on when im sitting in neutral after it has been warmed up.
There are no CEL's. I have checked my spark plugs, cleaned my air intake, throttle body, IACV, changed my PCV. It also has a new battery (problem occurred before the battery swap). Also when I check the voltage across the battery when the car is on, I only get about 13.4v not sure if it is related or not.
Any help would be great,
Thanks
Old Jun 10, 2012
94civicd16z6's Avatar
The Boss ;D
94civicd16z6 is an unknown quantity at this point
Re: Rough Idle and stall at stops
doesn't sound like a battery problem to me, 13.4 is a pretty good reading. sounds like the same way my old 90 accord used to run. it would start up good and idle fine, then when i stopped i had to push the clutch in and keep revving it up to keep it running at stop signs and lights. took it to a shop and found out the head was cracked and it was only running on 3 cylinders.. maybe do a compression check and make sure you still have a 4 banger
Old Jun 11, 2012
Freek21's Avatar
here's hoping that's not the issue. I'll give it a try, I know I have oil coming into the #3 cylinder hopefully not cracked though. It seems to have been progressively getting worse since I bought the car two months ago as well.
Old Jun 13, 2012
Freek21's Avatar
Ok so I did a compression test today, and everything seems to come back fine, I get 190psi in cylinder 1 and 180psi across the 2,3, & 4.
I changed my spark plugs last week to brand new NGK's and now #'s 1,2, & 3 are covered in black, could that be part of my issue.
Old Apr 15, 2018
MOJO_ERASER's Avatar
MOJO_ERASER is an unknown quantity at this point
I am having same issue I unplugged my mass air flow sensor and it runs fine I am going to replace it and see .... my car is a 09 1.8
jtdunn4life
Oct 27, 2015 03:33 AM
ywgflyer
May 15, 2015 05:05 PM
crowtoo
May 11, 2015 06:50 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
