Suspicious of Alternator - Blinker Weirdness and Rough Idle
Old Jun 9, 2015
jtdunn4life's Avatar
jtdunn4life is an unknown quantity at this point
2000 Civic DX Coupe
Rough Idle and the left blinker (only left) varies speed depending on what else is going on. If no headlights and no brakes it blinks faster than normal. With headlights on or brakes applied it blinks slower than normal.
Wondering if diode(s) in alternator is going bad causing a/c ripple in the system. No?
Any way to test it without removing the alternator?
Last note... I do have an aftermarket audio system with amps, etc. but it has been installed for years without these symptoms.
Old Jun 9, 2015
Re: Suspicious of Alternator - Blinker Weirdness and Rough Idle
Any halfway decent shop should be able to test it in the car.
Old Jun 14, 2015
Wankenstein's Avatar
Have alternator checked.
Clean all ground locations.
Reset ECU... http://www.clubcivic.com/forum/threa...eset-ecu.1180/
If you do an ECU reset after disconnecting negative battery terminal: Instead of waiting 5 minutes..just turn on your headlights, flash brights, and push brake pedal a few times to drain residual charge,,reattach negative start car.
Old Oct 27, 2015
shumatew's Avatar
shumatew is an unknown quantity at this point
Originally Posted by jtdunn4life
2000 Civic DX Coupe
Just an fyi, the left blinker sounds more like a bad relay.
jzhartman
22
Jul 23, 2015 10:42 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
cgavin1
Jul 7, 2015 07:10 AM
