1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
91 Si Rear Bumper Cover Removal
Old Mar 16, 2009
jamesdelaney's Avatar
jamesdelaney is an unknown quantity at this point
Hi, I tried posting this in the Honda Civic Si and Honda Civic SiR Forum but maybe it's better to try here. Anyway, hopefully someone out there has some insight into how to get the cover off the rear bumper so I can get at the bumper frame underneath it which is collapsing from corrosion. The bumper cover is sagging so much that I can see screws going from the top down into the cover but can't get at them because of a body-colored 2" wide piece of trim that wraps around the back of the car under the tail lights and hatch. How do I get that piece of trim off? Thanks.
Old Apr 8, 2009
Re: 91 Si Rear Bumper Cover Removal
Just bumping this thread up...anyone have any ideas? Thanks.
Old Apr 8, 2009
TRIZ's Avatar
Here is a picture of the parts involved on both bumpers:
Just look around to look for any screws or clips that might be holding it in place.. pop the trunk, maybe something is hiding there.. I couldnt tell you for sure since I've never taken the rear bumper off a 91 vic, although I have worked on them.
On the 7th generations the bumpers are held on by clups, and you just peal it away staring at one of wheel wells.
Looking at the picture it looks like there might be 4 or 5 clips or screws underneath that hold it in, as well as two behind the license plate.
Old Apr 10, 2009
Thanks, the diagram helps a little bit - the screws (pc 36) are the ones that go up into the body colored trim above the bumper that I think needs to come off somehow (this trim has the hatch lock cylinder in it). The only progress I have made is getting the extreme ends of the bumper cover off where I have access to screws (pc 33) at the rear of the wheel wells. If worse comes to worse, I'll probably wind up forcing the cover off and having to find a way to repair the holes which will be ripped but I can do it if I have to...although I'll still need access to put the screws back up into the trim I mentioned above to secure it!
Last edited by jamesdelaney; Apr 10, 2009 at 10:39 AM. Reason: fixed spelling error
usajags84
15
Aug 19, 2015 03:12 AM
Mercilus
Jun 7, 2015 10:00 PM
ilgnay
Apr 26, 2010 11:53 PM
sivic2k1
Dec 13, 2001 12:46 PM
1slo2k1civic
Nov 21, 2001 11:07 AM
