1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
HELP Crankshaft bolt issues...
Old Apr 19, 2009
airmech827's Avatar
airmech827 is an unknown quantity at this point
Hey there folks, new to the forum but have been a Honda enthusiast for several years now. current problem is trying to get crankshaft bolt loose on my 93 civic dx. d15b, the only catch is that the accessory drive pulley spins freely.(hopefully it is just a sheared keyway) is there any way to lock the motopr in place enough to break the bolt loose?
Old Apr 20, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: HELP Crankshaft bolt issues...
hopefully you have access to the tranny side. what i always do is: thread a bolt into the block (one of the threaded holes used to hold the tranny and block together) and then use another bolt and wedge it between the bolt you threaded in and the flywheel teeth. you insert a part of the head of the bolt into the flywheels teeth and let the bolt you threaded in the block act as a stopper, so the bolt wedged in the flywheel teeth cannot go anywhere. hence stopping the crank. get it? probably not its hard to explain lol. PM me if you got questions.
Old Apr 20, 2009
civcspool's Avatar
civcspool will become famous soon enoughcivcspool will become famous soon enough
you may need a special tool that holds the crankshaft pulley.You can purchase it at napa i think called Crank shaft pulley nut or holder around 19.00 bucks
Old Apr 20, 2009
airmech827's Avatar
thanks for the help, I actually got lucky today (and not so lucky) at work. one of the guys i work with brought in his impact gun and after beating on it with the imoact gun for about 5 minutes, it came loose. bad part is....looks like time for a used low mileage replacement. car currently has 275k on it and until the keyway sheared and my daughter drove it that way for 30 miles (not her fault) it ran great. the pulley managed to do some serious damage to the end of the crank. Keyway is jacked up and splines are no longer present as well as the fact that the threads on the boly appear to be messed up also. any thoughts or reccomendations on engine suppliers ( ie, JDM etc..)?
Bonobo
Oct 2, 2015 06:58 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
