1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
93 civic EX URGENT PROBLEM!!!
Old Dec 1, 2009
sublime0407's Avatar
sublime0407 is an unknown quantity at this point
Exclamation 93 civic EX URGENT PROBLEM!!!
Okay my ex has the d16z6 motor, but i had this sudden problem today. I turned the car on and seemed to run fine, until suddenly it started bogging then it stalled out. THen it will start back up but not very smoothly then it will run for about 10 min. tops and then bog and turn off. Even when idling it does this. I took it out and ran it and it was fine until it was idling for 5+ min. and it bogged and turned off? I do not know what is wrong???
Old Dec 4, 2009
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Re: 93 civic EX URGENT PROBLEM!!!
Do you have a check engine light on? It sounds like you having some trouble with the MAP sensor.
Jay
Fabricated Performance
Old Dec 6, 2009
no no lights are on and i ran dry gas and fuel injector cleaner through but i dont think its gotten the whole way through yet but no no engine lights are on and im sick of randomly having to pull off the road this is my daily so i need help asap please
Old Dec 6, 2009
BlueEM2's Avatar
Whachya lookin at?
Does it happen ONLY at idle??? or while your driving as well?
Old Dec 7, 2009
YSIDRAG's Avatar
Your answer... im sick of randomly having to pull off the road
Could be a few differant things. Coil and/or the igniter, fuel pump breaking down, map sensor. Unless you know how to test these parts yourself its hard for anyone to help fix it over the net.
Old Dec 7, 2009
alright well today i didnt even make it to school and its going on a computer up at a friends to see what is wrong thanks for the help though
Old Dec 7, 2009
BlueEM2's Avatar
Whachya lookin at?
LOL Thanks, I must have missed that one!
Old Dec 7, 2009
yeah its up at the shop as we speak lol but its prob not anything in the fuel line because the car shouldnt have even started back up all these times it would have just went off completely so it has to be electrical or some kind of sensor, but the sensor doesn make sense because no CEL is on o well waitin for the call to see whats wrong
Old Dec 17, 2009
eg8 project's Avatar
eg8 project is an unknown quantity at this point
i think its your fuel pump beacuse my civic was doing the same and it would run but then die out and it ended up being my fuel pump.
Old Dec 17, 2009
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
yea but without knowing what the specs are on it to do a dmm, makes it difficult. It could be still turning on, but going bad.
Old Dec 19, 2009
Okay well i guess i will try the fuel pump because when the car was at the shop it ran perfectly fine and now its acting up again i changed the battery in the car already becasue that was dying to from the car turning of and on constantly at the shop and while me driving it so i got a new one it started right up then the next morning the car kicked and then turned off i guess fuel pump is the next choice
Old Jan 15, 2010
bella_bean's Avatar
bella_bean is an unknown quantity at this point
hey did you ever figure out what was wrong with your car
i have a 1990 with the same problems, accept mine wont go for more then 10 mins before dieng.
Old Jan 16, 2010
"goose"Jay's Avatar
It could be the fuel pump, assuming that everything on your motor is assembled right. Is it emitting any smoke or smells?
Old Jan 17, 2010
bella_bean's Avatar
nope no smoke or smell, since this problem started happening we did the fuel pump, fuel filter, thermostat, catalitic converter, and main fuel pump realy..... we are stumped !!!
Old Jan 17, 2010
RonJ's Avatar
RonJ will become famous soon enough
Have the igniter unit in the distributor tested. Any CEL codes?
Old Jan 20, 2010
"goose"Jay's Avatar
check your dist cap too..had a similar problem with mine and replaced it with a new one and its all good now. Also check your intake sensors....map...tps...ettc. Its got to be a ignition or elec issue.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
Braun
Apr 23, 2015 09:03 PM
dooner24
Apr 14, 2015 07:51 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
