1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
92 Honda civic idle fluctuating wildly.
Old Dec 8, 2010
Vtec 92 boss's Avatar
Vtec 92 boss is an unknown quantity at this point
I have a 92 civic, amongst the pile of problems with this car a new annoying one has arisen. My car revs from 1000rpm-3000rpm while in neutral, or when the clutch is in. I replaced the IACV valve and it's still the same. With the two holes in the throttle body after removing the big black arm thing that holds the pod filter, covering the bottom hole makes the problem go away. Does anyone know the problem?
Known problems :
fried piston rings.
Radiator not working automatically.
engine has high revs usually (due to cold engine from radiator manually always being turned on)
Also engine has as far as I know, no coolant, just water. Lol.
Old Dec 8, 2010
civicnewb's Avatar
civicnewb is an unknown quantity at this point
Re: 92 Honda civic idle fluctuating wildly.
could be your throttle position sensor... or a hole in a vaccum line... i have the same problem in my 98 s-10 and cant find it.
Old Dec 11, 2010
Pretty sure it's not a hole in the vacuum line, where would I find the throttle position sensor?
Old Dec 12, 2010
bluhonda's Avatar
bluhonda is an unknown quantity at this point
this will fix your problem. on one side theres a plate with 2 8mm screws and the other has a small thermstate. most likly the side with the two screws is your problem. open it up and you will see a bulb just take a flat head and wind it down till tight. and all fixed have fun.
Old Dec 12, 2010
MindBomber's Avatar
Live for the Twisties
Thanks for that bluhonda, good tech answer!
Old Dec 12, 2010
bluhonda's Avatar
you are welcome
Old Dec 13, 2010
StaticFire450's Avatar
Bringer Des Blutes
StaticFire450 is an unknown quantity at this point
I would also check and make sure your coolant temperature sensor is working properly. If it is malfunctioning than it could be telling your ecu it is running at a low temp. So then it will tell you ecu to make you rev high to heat up.
Bad clutch and/or master cylinder?(just a thought)
Old Dec 15, 2010
Idk, does it help if I say it revs in gear aswell? Like my car can drive for a bit with no foot on accelerator.
Old Dec 31, 2010
Bringer Des Blutes
That still kinda sounds like the coolant temp sensor.
Old Jan 2, 2011
Still having problems with it, now it's starting to **** with my clutch, car revs high, but takes a bit for acceleration to catch up. How would I go about changing this sensor?
Old Jan 3, 2011
Bringer Des Blutes
It is located on the head. I could be mistaken, But I want to say it is underneath/next to the Distributor. It could be on the other side though. Ill take a look on my car, when I go out for break.
http://cgi.ebay.com/ebaymotors/ws/eB...m=180571952724
There is a link to what it looks like. It is very easy to replace. Rather cheap too. Lemme know of any other questions.
Old Jan 3, 2011
PhilmaGroin's Avatar
PhilmaGroin is an unknown quantity at this point
sorry guys i know this is not a related to this thread...but how do i start a new thread?
Old Jan 3, 2011
Bringer Des Blutes
Once your at the default location(Im guessing 1st - 5th gen section)
https://www.civicforums.com/forums/184-1st-5th-gen
At the top of the forum listings there is a blue botton. It should say 'Thread' or 'New Thread', It will be located by the page number selection.
Old Jan 3, 2011
thanks..i figured it out... it would be nice if somebody posted a reply on how to help my problem tho hahaha
Old Jan 3, 2011
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
dont forgot to back it out 180deg after you tighten the termo down otherwise it will malfunction as well. But yea a fit valve was my guess as well.
Old Jan 3, 2011
"goose"Jay's Avatar
under the dizzy its the only clip plug in there and its a 17 or 19mm bolt in sensor. i am almost 100% positive that is not your problem though. If its winding your rpms up 9 out of 10 times its a vaccuum leak. Low idle would indicate fuel or coolant issues. If your not throwing any CEL then its most likely not a elec or sensor problem.
Check your fast idle thermo valve
check all vacuum lines on the intake to and from
check your idle adjuster screw
check your timing even
also resetting your ecu couldnt hurt
but im almost 100% that your problem will lie in a vacuum line or port, best of luck to you though.
Old Jan 3, 2011
"goose"Jay's Avatar
also check the tb gasket.....thats honestly what it sounds like to me, when you replace it take some 220grit or whatever and make sure that the plenium surface and tb surface and hella clean.
Old Nov 11, 2013
bisso's Avatar
bisso is an unknown quantity at this point
My 92 civic si had this problem several times. The first time I ended up getting a new throttle body at a junk yard and that fixed it. The trouble code indicated TPS sensor which is riveted to the throttle body. The second time I had problems with the cooling system. If you have a coolant leak, clogged radiator, or bad water pump- the idle will be jacked. Also, after draining the coolant, you need to burp the system to get all air out of the cooling lines. Typically, bad sensor trigger trouble codes, but a bad radiator, water pump, vacuum leak or air in the cooling system will likely cause a hunting idle without triggering a trouble code.
Old Jan 1, 2014
woodsjd1's Avatar
woodsjd1 is an unknown quantity at this point
I would look at the ICA valve again...did you replace it with a new one or a salvage part...(or Ebay)...fill it with carburator cleaner and let it soak for a bit then flush it with more cleaner until it runs out clear...make sure O-rings are in place
Pr0n1s
Apr 30, 2015 03:08 PM
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
