1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
turn signal problem
Old Jan 11, 2011
skaraider's Avatar
skaraider is an unknown quantity at this point
turn signal problem
ok so i replaced the turn signals in the front today and went to test them and nothing works not front, back, ......the hazards work but not the turn signal switch itself, i checked the fuses and everything is good.. Does anyone have any ideas and a layout of the fuse panel... the car is a 95 civic
Old Jan 11, 2011
skaraider's Avatar
Re: turn signal problem
ok, so i put the old bulbs back in, and now my flashers won't work... im pretty sure its something in the fuse box thats kicking my ***.... the fuse for the flashers i had to replace because i changed the bulb out with the flashers on and POOF.. BUT anyways i still cant get my regular blinkers to work.. so frustrating and its prob something really dumb.
Old Jan 11, 2011
check fuses in the under dash fuse box, you have to take apart those plastic two covers and one of em says fuse on it. the fuse box slides down after you remove a screw i think and then you can check to see which is blown.
Old Jan 12, 2011
skaraider's Avatar
yeah I did that, I guess im gonna Remove all the under dash fuses and just put them back in one by one this is gonna suck.
Old Jan 12, 2011
or get a flashlight. you should be able to see the wire in the middle if its broken or not.
steveneddy
May 19, 2015 02:39 PM
Fastfebur
Apr 22, 2015 01:37 PM
blackbullet
Dec 1, 2001 03:44 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
GhettoCivic
Nov 12, 2001 03:15 PM
