1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
auto to 5spd conversion
Old Aug 11, 2010
white93coupe's Avatar
white93coupe is an unknown quantity at this point
ok i new to site and civic world ok i got a 93 civic dx and got a bad trans so gonna swap to 5spd what all do i need to do other getting linkage and clutch master and slave cylinder and trans and flywheel and a mount ? need help and post with pic from a diy would be nice
Old Aug 12, 2010
02civicsi02's Avatar
Low and slow!
Re: auto to 5spd conversion
Everything that you need is of course the tranni, clutch pedal, brake pedal, clutch master cylinder complete assemby (clutch master, slave cylinder, booster, push rod), passenger side mount, shifter assembly, shift cables/ shift rod which ever is needed, flywheel, clutch assembly, and a ecu. I think I covered it all there.
Old Aug 12, 2010
ok the only thing i confused about is how to hook up the shifter to floor cause i seen few ppl cut some of floor so what do i need to do i thought it was easy to just swap out auto shifter for 5spd so need pic an or a link to good diy thanks
Old Aug 13, 2010
majikmaster's Avatar
majikmaster is an unknown quantity at this point
all you need a hole cut in for is the clutch basically. Some models have a hole already, but a plug is in place. All i know really is that 92-95 EG models are a biatch cause of the master/slave cyl. hydrualic clutch system. Thats why i have a good ol' cable clutch in my 91 hb dx. lol
Good luck with the swap if you go through with it!
Old Aug 17, 2010
thanks for imput but yeah it has plug for clutch but last thing i confused about is does the linkage justbolt right up after cutting thatplat off where auto cable goes
Old Aug 21, 2010
Swiss's Avatar
Swiss is an unknown quantity at this point
do you need to use the manual lower front mount and rear mount for the trans?
solarpunk70
Apr 12, 2016 11:43 AM
ttamrekab
Sep 25, 2015 04:41 PM
meicalnissyen
Sep 25, 2015 12:12 AM
BJB
Sep 14, 2015 11:16 PM
rainman15
Sep 6, 2015 11:10 AM
