1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
wipers working on intermittent setting only
Old Jul 18, 2010
ssouci's Avatar
ssouci is an unknown quantity at this point
my '91 Civic HB suddenly has windshield wiper problems
PROBLEM:
the wipers work on the INTERMITTENT setting only... the LOW, HI, and MIST settings do nothing at all
washer fluid spraying is OK, as is the rear window wiper & spray
WHAT I'VE TRIED:
disconnectiong & reconnecting the wiring connectors under the hood at the motor, plus behind the control stalk switch assembly on the steering column, and also sprayed these with DeOxit contact cleaner... made no difference
pulled the motor assembly out, and visually, all seems OK (have no real way of assessing)... opened motor itself and cleamed out black powder... tried with motor sitting free (disconnected), and ran on INTERMITTENT only... motor seems to run fine and is very strong when I tried to restrain it by hand
15A fuse on fuse block is fine, intermittent delay relay seems to be OK since it makes a periodic clicking sound as the intermmittent wipers are running
ANY IDEAS? ... any help would be hugely appreciated! thanks!
PS: tried to gain better access to the stalk switch assembly, but for the life of me, could not loosen the retaining bolt that holds on the steering wheel, and was afraid to break my ratchet!
Old Jul 18, 2010
ssouci's Avatar
Re: wipers working on intermittent setting only
UPDATE:
I finally removed the steering wheel, so was able to get access to the wiper stalk switch connector... I then tested the switch pins for continuity, using the continuity test guide in my owner's manual... ran through all tests, in the specified order
the switch tested perfectly for all the switch settings, so I can assume the stalk switch is NOT the cause of the problems, so I reinstalled it (this had been my most likely culprit)
what next???
is it possible that the "intermittent delay" relay is somehow defective and preventing the other settings from working? speaking of that relay, I can hear it clicking intermittently (as it should) somewhere very near to the fuse panel below the dash, but cannot find it!... where is that relay and what does it look like? maybe I can open it and check solder joints etc.?
thx!
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
pratik05
May 15, 2015 01:54 PM
autowill
May 15, 2015 11:36 AM
shindrome
Exterior
May 5, 2015 02:50 PM
ORskier
May 3, 2015 12:54 PM
