1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
power steering
Old Dec 9, 2010
95EX's Avatar
95EX is an unknown quantity at this point
power steering
for some reason twice in the past year my power steering fluid has found its way out of the right side of the steering rack???
anyways for the time being i want to put some stop leak in the system to maybe keep this from happening again. Is there one recommended stop leak for hondas since they require a special steering fluid?
Old Dec 9, 2010
89civichatch's Avatar
89civichatch is an unknown quantity at this point
Re: power steering
not really the best idea,have u checked ur boots and all the lines to see if they were leaking on that side,could be something cheap and easy to fix.
Old Dec 9, 2010
Re: power steering
you using honda fluid right? if so, then you may need a new rack. hard to say without seeing pics of where and how much fluid. generally, stop leak additives rarely work and usually cause more problem.
Old Dec 10, 2010
95EX's Avatar
Re: power steering
yes i use honda fluid
my right boot is ripped and its coming from there, something inside obviously busted. Ill probably get around to trying to fix any seals that are in there but was just wondering if some stop leak would help for the mean time.
are there seal rebuild kits for racks?
Old Dec 10, 2010
mike2310's Avatar
mike2310 is an unknown quantity at this point
Re: power steering
how do you post a new message on this site. i am new and having troubles with my cooling system.
Old Dec 10, 2010
Re: power steering
95ex,no they dont sell just the seals,mine was doing the same thing and i had to buy a new rack and pinion,but go on ebay and they r alot cheaper and they r from a part store.good luck
NoobyKid
Jul 13, 2015 07:53 AM
hans.pcguy
Jul 12, 2015 12:19 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
hayden55
Jul 8, 2015 11:38 PM
cgavin1
Jul 7, 2015 07:10 AM
