1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Please helpp!!! Asap!!
Old Oct 4, 2010
H3RKID's Avatar
H3RKID is an unknown quantity at this point
Unhappy Please helpp!!! Asap!!
ok so i wanted to build my first car....thinking it would be hard but not this much of a pain in the ***...so i bought a 94 civic ex (eg) shell....then i bought a d15b2..and i changed the dizzy and changed it from dpfi to mpfi ...then bought a obd1 engine harness...installed a d16y8 hydro tranny ...got a free p75 ecu (integra ecu) pieced it all together...fuel pump doesnt work and theres no spark....main relay checks ok...ecu checks ok...all fuses are good....could this be a ecu compatabilty issue? if it is what ecu should i use? take note that i said its an older d15b2 in a newer 94 civic ex. 94 civic ex's came stock d16z6...i have no money for another swap i need to make this work or else i have to junk the whole car and lose all my moneys worth someone please help me!!!
Old Oct 4, 2010
H3RKID's Avatar
Re: Please helpp!!! Asap!!
bummmmmp!!!!
Old Oct 8, 2010
phil_89's Avatar
phil_89 is an unknown quantity at this point
... are u shure about ur ecu... check the ground for ur ecu the one on ur thermostat
Old Oct 9, 2010
H3RKID's Avatar
problem solved it was the thermostats ground wires lol ecu is fine with the motor tho
