PDA
View Full Version : Exterior
  1. program remote without original?
  2. 2010 civic side view mirror
  3. My TRUNK - Honda Civic LX 2020 just stopped opening.
  4. 2015 Civic LX Front Windows Stopped Working
  5. How to remove outlet air vent 07 Civic
  6. "downgrade" passenger side mirror ?
  7. Do I have to replace my door lock actuators or can I do something to fix them
  8. 2010 civic LX wiper issue
  9. Something came off as I was driving.
  10. 2014 Civic LX - Engine Splash and Cover
  11. front bumper
  12. Need Help Identifying Bumper Part 2006 Civic
  13. What fender to buy? Honda?
  14. 2007 Civic back glass, sedan coupe
  15. Molding removal
  16. How to replace Rear Passenger Weathersrip
  17. What is the purpose of this bolt used under driver-side of 2013 Civic
  18. Si emblem Install
  19. Water dripping in the trunk ?! [solved]
  20. 2013 EXL skid plate mounting bolts
  21. Key Stuck in door
  22. Wondering if my rims and lower grille are ok(2015 Honda civic SE)
  23. Occasional lock/unlock issue
  24. Help 2013 rear door issue
  25. Passenger Mirror Replacement Questions
  26. Rust Repair
  27. Are they the same
  28. Color code for the Color for that Honda civic blue
  29. is this 2010 Honda Civic repairable? [solved]
  30. Unibody has rusted out
  31. Replacing Door. 07 EX
  32. Honda Civic 9th gen 2015, Drivers door issues!
  33. Fuel Flap Lock
  34. Lock/ Unlock
  35. Civic mk9. Both rear power windows not working
  36. Cracked windshield
  37. Trunk Switch
  38. Trunk alignment issue
  39. Inner Fender Liner (Right Side) 8th Gen Civic EX 2006
  40. Dented rocker panel
  41. Window switch wiring
  42. Issue with Gas Tank door staying shut (Civic 2015 EX)
  43. Hello, will the 9th gen 2012 Honda civic Si front grill fit the Honda civic 2012 Ex?
  44. Repair scrape on car
  45. 2012 locks won’t open with key! [solved]
  46. 2014 Civic Gas/Trunk open lever is broken
  47. Side mirror is wobbly
  48. 07 si fg2 window liner
  49. Undercar shield screws?
  50. Window stopped working
  51. replace broken vent window
  52. 2006 honda civic ex back window install
  53. 2006 civic fuel door in-op
  54. '07 DX-G Coupe (Canadian) in Nighthawk Black Pearl - clear coat gone
  55. 2009 Honda Civic headlight set replacement
  56. Headlight replacement 2015 EX
  57. how to remove/install 2008 civic door trim(protector)
  58. 2007 Honda Civic Windshield Sealant
  59. broken portal window
  60. Hit a pot hole and bottomed out. What do I do?
  61. 8th Gen Civic Rear Quarter Panel Rust
  62. 2008 door lock issue
  63. Looking for a replacement front right Fender Wheel Liner
  64. Bad paint. Trying to sell
  65. Windshield trim
  66. 08 Civic EX Door lock problems
  67. Need Advice on fixing deep scratch [solved]
  68. Is this collision damage fixable? - 2007 Civic LX
  69. 8th Gen Civic Passenger rear door water leak.
  70. What are your thoughts? | 2006 Coupe, 60k Miles... Collision Repair
  71. Window channel/runner separating?
  72. Wiper issue
  73. Best primer for quarter panels?
  74. How do you deal with clear coat fade?
  75. Honda Civic Lx 2007 sedan Front bumper
  76. 2009 white Honda Civic, paint is peeling all around the back window
  77. How can I re-attach this? 09 Civic. Happened to my Dads 11 Accord as well.
  78. Replacing front indicator light (right) Civic Gen 8
  79. Will a front bumper with headlight washers fit my MK8 that doesn't have them?
  80. Rust repair on fenders
  81. Bumper clip
  82. Is the driver's side fender liner for Civic same as CSX?
  83. Will any 2006-2011 Civic doors fit my 2007 Acura CSX?
  84. Locking issue in my 2009 Honda Civic
  85. windshield wiper cowl plastic piece
  86. 2014 Civic pillar garnish front replacement HELP!
  87. Door attachment nuts fell off inside frame
  88. Help - How Do I Fit The Gas Lid Cable Into Grommet
  89. remove paint and primer from windows 09 civic
  90. ‘12 civic manual key entry
  91. 2013 civic si coupe
  92. 2010 Honda civic hybrid mirrors fold
  93. Rear Trunk Button Quit Working - 2014
  94. Help With 2012 Civic
  95. Front Bumper Came Loose [solved]
  96. 2010 Civic Si foglights fit on 2010 Civic dx-g coupe?
  97. Is my 2012 civic totaled
  98. 2006 Sedan, location of sunroof drain (outlet) ??
  99. Civic 2008 Sedan Bumper Replacement
  100. PLEASE HELP: Roof molding removal - 2012 Civic LX Coupe
  101. 2011 civic fuel door problem
  102. Wipers
  103. Need repair info from raccoon hit - 2010 EX sedan
  104. 2009 Civic back door will not open
  105. Paint Peeling
  106. 2009 FK1 disassemble Rear trunk light?
  107. 2015 civic paint damage
  108. 2012 Honda Civic LX - Underbody Plate Issue?
  109. Locking issue?
  110. Heat Shield on 07 Civic Sedan
  111. Window goes down but not up.
  112. Side Mirror glass
  113. Plastic/Rubber bolt/clips for under-frame?
  114. Water in the floorboard
  115. Windshield wiper motor issues
  116. Bolts/Push Rivets for part 74110tr3a10
  117. 09 civic sedan rear pass doorwill not open sometimes
  118. Please Help!
  119. Clips
  120. Driver side mirror
  121. Washer Fluid Low Light Issue
  122. Tools needed to replace radiator support 06 civic
  123. Trunk locks but does not sit flush
  124. Civic 2012 auto Doors lock.
  125. mysterious windshield leak?
  126. Will 2005 bumper fit on 2008 civic ?
  127. 06 Civic; PLEASE HELP ASAP!
  128. 2015 Honda Civic Front License Base
  129. Roof rack
  130. Power Windows not working
  131. Paint code help
  132. Trim Damage
  133. Trunk won’t open by key or by lever 2015 civic
  134. Need window stripping. What's the name?
  135. 2012 Honda Civic DX Door Lock Cylinder Replacement
  136. Headlight upgrade.
  137. rear side window blown out!!
  138. Trunk key won’t turn
  139. 2010 EX sedan window channel molding rippling/folding outward
  140. 2006 Civic EX coupe 5speed trunk won't open
  141. Loose rear drivers side door handle
  142. 2010 Civic - Urban Metallic - Paint issues
  143. Can you tell me what this is? 09 Civic
  144. hood replacement for '07 Civic Si
  145. Windshield side trim rubbers missing?
  146. Removing Alert
  147. 2015 Civic LX Trunk lid replacement
  148. Passenger Door Handle Cap Coming Off
  149. New member here, 2007 Honda Civic Coupe lock issues
  150. 06 H Civic Hybrid I cant open the door with the remote key or manually?
  151. Door Unlock Issues
  152. 09 civic rear door will not open using inside or out handle
  153. drove over '15 fob, what best way to replace it?
  154. Fuel door lever doesn't work 2014 civic
  155. 2007 Civic windows and locks stopped working
  156. Body work
  157. 2010 Civic Door Lock Issue
  158. Windshield Molding Replacement
  159. Wipers and Washer both don't work
  160. Doors won't lock by the remote if a door is open
  161. Help me find the part - Window seal / window weatherstrip
  162. Help Identifying this part
  163. sunroof has a mind of its own
  164. 2007 honda civic lx washers inop
  165. Guess this sensor?
  166. Car Wash Damage??...or Honda Paint Failure??
  167. Trunk light issue Civic 2006
  168. Obsessing over trim fit
  169. Side Molding Repair
  170. 2006 Civic Locking issues
  171. 2015 Civic Driver's Window
  172. unibody has rusted out
  173. 2006 Honda Civic Hybrid - Drivers Side Window Problem
  174. 2011 Civic Blackout Tape Around Windows
  175. Was in an accident. 06 Civic EX. Opinions on outlook (w/ pics)
  176. Bumper Issue
  177. Weird Door Frame Paint Degradation
  178. Trunk/Fuel Door Release Cable - A Different Kind Of Question
  179. Part Identification - Front Driver-Side Fender
  180. 2008 Civic 2-door (lowbeam replacement) passenger-side
  181. 2006 EX Sedan Hood/Bumper
  182. original wipers Mitsuba?
  183. 08 Civic center console help (latch)
  184. window issues!
  185. sunroof drain tubes - best way to unclog?
  186. 8th gen sedans and weak door "checkers"
  187. Windshield Wiper Problem
  188. Right front fender rattle
  189. 2006 Honda Civic driver door lock problem.
  190. 06 civic ex 4dr door lock issues
  191. 2006 Civic Remote Entry Problem
  192. Automatic window not working
  193. How can I trip my trunk light sensor so the light will go off?
  194. Glass Replacement Outside Mirror
  195. Best product for plastic repair?
  196. Central locking gone?
  197. rear bumper crack on 07 civic coupe
  198. Wiper blade problem
  199. help?
  200. 2004 Civic EX trunk latch bounces open
  201. Right mirror smashed
  202. 2009 civic LX-S Front Bumper
  203. Install Side Mirror Glass
  204. 2008 Windshield Washer Fuse and Motor
  205. 2006 EX Wiper Motor Cover Plate Replacement
  206. Would like a spare key for 2006 Civic LX
  207. 06 civic si cracking paint
  208. Front Bumper Face Replacement - Need Help
  209. HELP: how to unlock car door latch?
  210. Help Replacing front bumper cover 08 civic si
  211. 08 Sedan (Si) Door Panel Removal
  212. Replacing Front Bumper on 2006 Civic...
