Help 2013 rear door issue
Old Sep 26, 2023
Bmck78's Avatar
Bmck78 is an unknown quantity at this point
So maybe someone is out there that knows these cars very well can help.
So after a trip to the body shop I notice my driver side rear door isn’t opening from the outside. Inside was opening fine. Unlocking fine and window is fine. As I was investigating, I hit the child safety tab and closed the door. So now the door won’t open at all. The handle doesn’t have much tension so I’m guessing the rod of the handle is off or broken or the inter handle tab is broke.
so what’s my play here?
can I slim Jim it open? If I get the panel off can the outside handle be reached. Obviously the latch can’t be removed with the door shut. I don’t think the child safety switch can be reached with the door shut and panel off.
Any help would be appreciated.
thanks.
Old Sep 26, 2023
BrotatoChip's Avatar
Super Moderator
Re: Help 2013 rear door issue
Take it back to the body shop if they broke it?
Old Sep 26, 2023
Bmck78's Avatar
I don’t know they did that. The work was to the front bumper and they had no reason to use the rear doors. I haven’t opened it in a long time and no one has ever sat back there. It could’ve been broke for years.
Old Sep 26, 2023
Super Moderator
Oh, nevermind then. Probably your best option is a slim jim. Someone else had to do this recently, but if I'm remembering correctly it was an older generation.
edats
Interior
Jul 31, 2019 08:30 PM
carvedtop
May 28, 2012 01:20 PM
rayaman2
Mar 17, 2011 02:58 PM
manofsteel517
Nov 7, 2009 05:19 PM
ZSKCivic01
Jul 11, 2003 03:33 PM
