Trunk Switch
Old Apr 4, 2023
Meanie's Avatar
Meanie is an unknown quantity at this point
Trunk Switch
The trunk switch for my 14' civic coupe stopped working. The remote works and the cable pull works so I assume it's just the switch. Anyone know if it can be fixed or just easier to replace? I'm trying to save a little money. Thanks
Old Apr 5, 2023
BrotatoChip's Avatar
Super Moderator
Re: Trunk Switch
What switch are you talking about?
Old Apr 5, 2023
Meanie's Avatar
Re: Trunk Switch
The trunk switch at the upper right corner of the license plate. It opens the trunk from outside. It's one of three ways to open.
Old Apr 5, 2023
Super Moderator
Re: Trunk Switch
Ah, where you insert the key to open the trunk. When you stick the key in does it still let you turn?
Old Apr 5, 2023
Meanie's Avatar
Re: Trunk Switch
Mine doesn't require a key. It opens via fob, lever inside or that switch.
Old Apr 6, 2023
Re: Trunk Switch
sedan? coupe? Hatch?
Old Apr 6, 2023
Meanie's Avatar
Re: Trunk Switch
Stated in my original question. Coupe.
Old Apr 6, 2023
Re: Trunk Switch
ah, my bad.
my mazda CX5 had an issue of moisture getting from the rear windshield wiper that cause issues with the switch, not likely you case then
EBP EX
Jul 13, 2007 02:26 PM
player
Sep 4, 2003 01:09 PM
biohazard
16
Aug 26, 2003 07:27 PM
cosmo
Jul 18, 2003 09:04 PM
WhosYoDadday85
Feb 10, 2002 08:35 PM
