New member here, 2007 Honda Civic Coupe lock issues
Rep Power: 0 New member here, 2007 Honda Civic Coupe lock issues
New guy here....I'm trying to find out some info about my daughter's car before I plunge into fixing it. 07 LX coupe, the door lock will not open. We don't have a remote fob as the car was a repo. The trunk lock and ignition lock are fine. About a week ago the tumblers on the drivers side crapped out. I found a youtube video showing how to remove the lock. Kinda looks like a PITA, but doable. 1) Would it be feasible to easily remove the trunk lock and switch the locks? I haven't seen how to remove the trunk lock, if that should be an option. 2) Having a locksmith fix the tumblers, probably cheaper than a new lock assembly, but if I need to go to Honda, will the title/registration give them all the info to check and see if they have a lock on hand or need to order one? 3) I've seen the remote fobs that are sold online. I've heard it's impossible to DIY program on your own, but I've seen threads/videos where it says you can. If I got a blank key with a fob is it possible to self program it with a "key sequence" to use it to open doors/etc. Thanks in advance, Chris....
Re: New member here, 2007 Honda Civic Coupe lock issues
Ask your locksmith about it, it's part of the immobilizer key programming process.
If your locksmith doesn't have equipment to work with Honda sidewinder locks and keys, call your dealership.
JD101
07-19-2017 10:59 AM
acmrrll
02-21-2015 02:12 PM
Liusan
10-10-2012 02:57 PM
