08 Civic EX Door lock problems
Old May 25, 2022
marcorosano's Avatar
marcorosano is an unknown quantity at this point
Hi All,
I just bought a 2008 Civic with driver side door lock problems.
Basically the key will not turn to the right in the driver side door, so if the battery ever dies it means that I can't unlock the car.
I already replaced the actuator, and while it was out the key moved freely in the cylinder, so I think the cylinder is ok, and the actuator is new, so I'm assuming that's ok too.
I got a new key FOB and it works perfectly, but I hate the thought of ever having a dead battery AND having to break into the car to do anything about it.
Any ideas? Thanks!
- Marco
Old May 25, 2022
Re: 08 Civic EX Door lock problems
when the battery dies, you can use the key to unlock passenger door
Old May 26, 2022
There's no door lock cylinder on the passenger side. Driver side is the only one.
Old May 26, 2022
Minor update: I found that if I really force it I can unlock the driver side door mechanically with the key.
I guess that'll do for now, but it'd be nice to actually figure out what's wrong with it. Hmm.
Old May 26, 2022
Colin42's Avatar
Tried lubricating anything yet?
lock cylinder might be tired, they can be rebuilt.
Old May 26, 2022
whoa, they were really looking into cost down then for the 8th gen cars...
Old May 26, 2022
Yeah - I got a good amount of oil into the lock.
The thing is when I had the actuator disengaged from the cylinder the key worked really smoothly in the cylinder.
Then when I hooked up the actuator and plugged it in it just locked up and doesn't turn to the right just like the old actuator did.
I think I'll try replacing the cylinder just to see if it does anything. I miss my 93 Accord 5 speed.
Old May 26, 2022
Colin42's Avatar
New actuator is probably the issue then
sjs8415
Exterior
Feb 2, 2020 03:16 PM
tookdrums
Feb 3, 2016 11:32 PM
acmrrll
Feb 21, 2015 02:12 PM
eazy42
Dec 28, 2011 01:44 PM
diggitydog
Apr 10, 2011 02:16 PM
