2006 Honda Civic driver door lock problem.
I have read a few threads on door lock issues and none of them explain exactly what is happening with my driver side door. I was wondering if some of you might post what you think is the problem with my door lock. I would really appreciate it.
Anyway, I put my key in the driver side door today to open it and the key turned to the right and did not bounce back, nor did the door open. I had to force the key back to the left to get it out of the door. I tried to use the remote to open the door and it would make noise but not unlock. I went the the passenger side door and used the remote, it unlocked the door and I was able to crawl in and drive home. When I arrived home I tried to unlock the door manually from the inside and it continued to be stuck in the lock position. I pushed the automatic door button on the inside and was able to open the door between the time I pushed the button and when the door clicked back to the locked position. I read on other threads about the actuator, but they seemed to describe the remote not working at all for this to be the issue. Does anyone have any ideas.
Thank you very much.
astateofmind
Aug 20, 2013 08:11 PM
