View Full Version : General 8th & 9th Gen
- Civic S 2.0 2006 - my parts are the same as the civic Si ?
- Are the 2012 EX 4dr Sedan vtec?
- Will removing steering knuckle interfere with struts
- cargo measurements, 9th gen hatchback
- 150k mi. 2013 LX intermittent starting problem Fixed
- What year is best with minimal issues for used Civic between 2006-2015
- Quick question (K-Engines) [yes, I am dumb]
- Should the exterior temperature be displayed? [solved]
- Just bought my 1st Honda
- Hubcaps 9th gen
- Cheapest way to make a stock civic pop
- 2010 Honda Civic vs 2007 BMI 328i for 18yo
- Found another civic, advice needed.
- tow bar base plate
- Project GPS onto the monitor??
- Considering a 2010 Civic with over 250K Miles
- Honda Civic MK8 Trim Levels (UK)
- 2013 Honda Civic lx Brakes
- 8th gen vtec
- Buying a 2008 civic SI with 110,000 miles, what’s a good price to buy?
- '14 LX Wiper Stalk/Turn Signal Stalk Replacement
- Searching a Service Manual
- Dirty engine bay
- Flat towing a 2007 Civic with manual transmission
- 2015 civic lx sedan muffler size
- 2012 Honda Civic Lx Parts Available on Ebay
- fuel indicator level vs. range km indicator
- Car stalls with Brake Engaged
- Cannot tune FM band after battery change
- 2012 ex fuse identification
- 12V System Short
- 08 civic clutch engagement question
- 1.8 V-tec ltr Civic 9th gen.. how gutless is it?
- 2008 Civic won't pass CA Smog Test!
- Services
- buying a used 2015 civic-any advice for me?
- Buying Honda Civic 2008 Coupe with 264000 km mileage
- Better shifting
- Direction needed for 8th gen car buyer plse
- How to Know if My 09 Civic is “early” [solved]
- Throttle performance
- Trim levels
- Whining noise
- Opinion on which model is best
- 2014 9th Gen Civic 'Passenger Airbag' Light Always On [solved]
- Can I use transmission fluid for power steering fluid?
- 2009 Honda Civic Sedan Stock What should I do?
- What is this white box? Honda Type S engine [solved]
- New here (looking at a 2015 EX)
- Is this normal? Revs jump up to 1500RPM after letting go of gas pedal.
- 2010-2013 used recommendations - carfax?
- 2009 ex coupe at. Headlight assembly
- Block heater location
- 2015 civic key fob
- Drip molding
- Buying Advice - 2009 Civic - 100K miles
- Common issues to look for when buying a 8th Gen Civic
- Headlight Assembly
- New owner 2015 LX 4dr 5 speed
- Two types of keys of Honda civic 2010
- Need Help | Unusual Use Case - I need a Class 3 Hitch
- Honda civic 2011 keyless entry install?
- Hybrid steering issues
- Dome/Interior dome light glove box light
- Best Tool Set: 9th Gen Civic EX-L
- Remote Start
- 2013 honda civic sedan ex auto trans
- 2011 DX 5-speed 1.8L 4-cyl
- 2012-2015 Civic Hybrid Question: Are they reliable?
- What’s Undercarriage?
- Most commonly used tools
- How on earth do I find my 2006 civic model type?
- difference between Honda 2.4L DOHC I-4 vs K24Z7 engine
- E3 Spark Plugs for Civic
- Engine code p0134 and p1658
- Things on the look out for '09 LX?
- Anyone here flush their heater core?
- What vehicles are on your kill list?
- Engine code R18A1 vs R18A4
- Looking to upgrade a few things plus questions
- Red Light Behind Rearview mirror
- Can you install 195/60 R15 on Civic DX 2012?
- New to Civic need buying advice
- VIN number in ECU does not match car
- Help identifying missing part
- Bowtie image
- Recommend me a Civic?
- Need answers ASAP on buying a 9th gen
- 06 Civic EX 1.8L fender liner/splash guard front end
- Project car questions.
- 07 GX conversion to gasoline
- Looking for a cheap Android multimedia for my Civic 2010
- Etched VIN number for tracing on a paper (2015 Civic)
- remote starter
- Honda Civic 8th gen. Hidden Menu
- Blinking blue light when driving
- 2007 Civic - Buy or Not Advice
- Shifting Gears
- Asian Car parts
- Common 2015 Honda Civic EX problems
- Unknown sensor
- 2014 key replacment
- 2012 civic
- Honda Civic Coupe 2007
- PrecisionWorkz Retrofit Complete Headlights
- Best dash mount for non-flat surface
- 2006 Honda Civic General Question
- Free engine replacement for 2006-2009 Honda Civics
- 2008 Civic, a good buy?
- 2010 civic lx-s new front strut recommendation
- Upgrade wipers to full intermittant
- My 2007 Civic LX “mod” thread
- Service Manual for 2007 Civic EX
- How to make seats more comfortable?
- 2006 Honda Civic hybrid
- how many revs per gear
- 2013 9th Gen Full Suspension for Highway.
- Upgrade to "Premium Sound"?
- Cheap and easy mods
- Are 8th Gen Civics easy to steal?
- fastener for 2013 washer tube?
- How do I get the radio code in my 2015 Civic
- Upgrade Headlight & interior bulbs?
- Fuel economy 1.8 Petrol
- Jack
- Seeking purchase advice
- turn steering wheel & engine RPM increases
- CVT Question
- Outside Door Handle
- EPS warning disappears when engine turned on
- 2014 1.8L EX - Wiper Blades and Serp Belt Change
- Low beams not working
- How to see the first post of a thread first.
- How to start a manual without the clutch depressed
- honda civic 2008 doing just 9 km per litre
- 09 Civic: Suggestions for Struts & Shocks??
- 2012 civic LX - Stereo Questions
- Clutch or Starter or Alternator 2009 Civic Si
- body shop
- 2012 Civic VIN?
- What's compatible model for 2007 FD2 Civic 2.0?
- Thinking of buying this hybrid that basically sounds like a tractor when it's idling.
- 2013 black paint fading
- PCV Valve cleaning, throttle body, maintenance
- 2010 - removing door panel that won't open (broken latch cable?)
- Bluetooth music problem
- No power to A/C nor Defroster nor rear defroster nor interior blower.
- Need part, but don't know the name
- Replace or not.
- 06 HCH upgrade questions
- Civic 8gen
- 06 Civic Sedan EX - AC not blowing cold air
- CVT Fluid Change on 2015 Civic
- Has anyone ever had Moisture on driver side carpet near gas pedal?
- What is this part called...?
- Best 8th gen dash-top mount?
- 2010 civic air cond. blows not so cold sometimes
- key doesn't open trunk
- 2012 Civic Si airfilter
- 2010 Civic AC issue. NO Lows side pressure
- Which Forum should I post my Sound-Treat/Deaden Project?
- 9th gen purchase pro/con questions
- fuel economy
- Replacing hood on my 2008 Civic
- Honda Civic 2011 floor mats
- 2011 civic ex transmission fluid change question
- paint protection film
- Low beams too dim
- Part Swapping Question
- 2012 Civic Driver Seatbelt Swap with Passenger
- Magic seats not flipping up
- Maintenance schedule
- watch where You park People...
- To Si or not to Si?
- F3-11 /Permanent DTC, Civic 2014 SRS error
- obsession with the 2011 civic sedan
- weather stripping
- Alarm does not set from key
- 2006 Honda Civic 1.8l oil in spark plug well
- Buzzing from inside dash
- Fuel door won't open
- tpms 2010 civic
- 2006 civic 2dr should I buy?
- Whining noise that stops when pressing the window button
- Crash course on 8th and 9th genz needed
- screeching noise Coming from Engine
- 2015 Civic Coupe LX RF Rack.
- Honda Civic 2007 ex stereo makes random popping and cracking sounds
- 2010 honda civic door sill film
- Carbon Cabin Air Filters
- 2011 Civic ex Honda H emblem
- 2012 civic, heater hose valve location
- Cup Holder Insert?
- 8th Gen Hybrid Mods
- 2013 Civic (LX?) Bluetooth Audio sounds weird
- Tail and amber lights won’t shut off
- Cabin air flow.
- A/C Issue
- 2012 Civic, Rodent in cab filter housing and fan
- source to buy a couple interior parts?
- clear coat
- Lowering 8th gen on shocks and springs
- Key question..
- Problem with power windows
- 2015 Honda civic coupe head room
- Considering a 07 Civic Si.. Pull the trigger?
- Window tint
- 2013 Honda Civic LX Fuel economy not as good as expected
- Mechanic Obligations Regarding Misdiagnosis?
- Is my Honda Dealer pulling my tail?
- '13 Civic Modifications
- Rubber Cork Popped under hood
- sell as is or fix first.
- Leary of 8th Gen
- looking to upgrade to 2008-2012 Civic. Any issues to be aware of?
- Future Civic Owner (hopefully, Pls help)
- How Much Power Can The CVT Withstand?
- help figuring out year of civic to get
- Civic FG1 & FG2 Reliability Questions
- 2006 - what to watch for
- 2013 Honda Civic Steering Fluid
- new here and question about the civic complaints
- '08 Civic Tint Shade?
- 2010 Civic LX-SR
- Help with 2010 Honda Civic
- Lack of parts for 4 DR 8th gen Civic's....
- chicka chicka yeahh look what i got
- Civic Lovers: HELP!! What can I do? Would you tollerate this?
