General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
2008 Civic won't pass CA Smog Test!
Old Aug 11, 2021
JoeLABronx's Avatar
JoeLABronx is an unknown quantity at this point
It's only got 70k miles. Serviced regularly BUT won't pass the California Smog Test UNLESS it's driven at 55MPH for an hour RIGHT BEFORE TESTING! Anyone know what is causing this problem?
What needs to be FIXED/REPAIRED/REPLACED? ALL RESPONSES WELCOME!!
Old Aug 11, 2021
Re: 2008 Civic won't pass CA Smog Test!
Sounds like you have a check engine light that you're clearing before the test. All sensors have to be in ready prior to testing, hence the 55mph for an hour thing.
That said, do you have a check engine light on? If so, get the code read (auto stores like AutoZone read codes for free) and post up what code they say is popping up
dacivic
Mid Atlantic
Oct 25, 2002 01:44 AM
MikeyBoy
Mar 5, 2002 10:49 AM
